Community
What do I need to c...
[Closed] What do I need to convert DT Swiss 240s rear hub to 10mm bolt-through?
Want to convert my DT Swiss 240s rear hub from QR to 10mm bolt-through (have already done so to front, with 9mm).
Is this what, and all, I need?
1) http://www.chainreactioncycles.com/sg/en/dt-swiss-conversion-kit-qr-to-10mm-thru-bolt-rear/rp-prod23845
2) http://www.chainreactioncycles.com/sg/en/dt-swiss-rws-thru-bolt-alloy/rp-prod81162
Posted : 17/11/2013 8:29 am
 jimw
When I did the conversion I had a new axle as well as end caps, , but it was a 240 rather than 240s if that makes a difference?
Posted : 17/11/2013 10:37 am
Yes, but I think the 6-bolt and centre lock versions maybe use different end caps? Worth checking before buying.
Posted : 17/11/2013 12:01 pm
I have roval traverse el wheels and the hub is based on either 240 or 240s hub.. initially told was the 240 hub so nesded the axle and caps.. since seen a thread on mtbr where joe roval (from the company) states its just endcaps cos its based on the 240s...? Hopefully it is, cos a new hub axle is a bit steep!
Thru axle wise I'd just get a superstar one.. prob heavier but a third of the price..
Posted : 17/11/2013 12:36 pm
