What compression-le...
[Closed] What compression-less brake outer?
Any recommendations for the above? For a set of BB7's that I want to make less spongey. Ideally towards the cheaper end of the spectrum.
Posted : 03/04/2018 11:06 pm
Wiggle lifeline pro something or other.
Just fitted some and it's loads better than normal cable outer. I ended up buying a second pack though as I didn't have enough in one pack for both brakes. May be my fault cutting it though....
This oneย  http://www.wiggle.co.uk/lifeline-performance-brake-cable-set-shimanosram-road/?lang=en&curr=GBP&dest=1&sku=5360675947&kpid=5360675947&utm_source=google&utm_term&utm_campaign=UK_PLA_Components&utm_medium=base&utm_content=mckv%7cshemImE56_dm%7cmcrid%7c67090789502%7cmkw%7c%7cmmt%7c%7cmrd%7c5360675947uk%7cmslid%7c%7c&mkwid=shemImE56_dm&pcrid=67090789502&prd=5360675947uk&pgrid=17507338502&ptaid=pla-131252089502
Woah that link is massive!!
Posted : 03/04/2018 11:15 pm
Try 5mm gear outer.
Posted : 03/04/2018 11:18 pm
I use small diameter aluminium tubing for the parts of the cable run that do not need to flex. I line it with teflon airhose.
The only snag is you have to make it up yourself.
Makes a dramatic improvement to cable brakes.
Posted : 04/04/2018 1:24 am
The way the cable is cut and finished also has a big effect. Often overlooked.
Posted : 04/04/2018 9:10 am
