Last bottle of squirt just finished so thought I’d ask you lot what dry lubes you are using and how they last when the going gets wet and muddy?
Tia
still putoline boil in the tin wax here! Much cheaper, much more effective than anything I have tried. Couple of hundred wet and muddy offroad miles, thousands on road
Muc-Off wet lube. Cos it smells nice.
Chain line varies as I have 3x9.
Glad I could help 🙂
53mm
Smoove - 40-50 miles in mixed conditions, if applied correctly.
I use the finish line stuff but it doesn't really cut it when it rains hard. I get chainring grind after 5k or so.
Slopping a bit of wet lube on after a quick wipe with a gt85 soaked rag doesn't take long though.
I'm just trying out Purple Extreme. So far with very good results. I've done a couple of 100km rides with river crossings etc and not needed to re-apply anything. Squirt I found to be useless on anything above 30-40km.
Rock n roll blue extreme. It's not cheap, it just works, and my chain/cassette stays clean.
Putoline if you're some kind of morphed Fred Dibnah/sado masochist, with a house that smells like a firelighter manufacturing plant.
Purple Extreme - excellent stuff. Just make sure you apply it post-ride ready for the next ride rather than pre-ride so it has a bit of time to dry out.
Used it for years, and have dabbled with other lubes but always come back as it's far superior
Stick with Squirt.
Been using it for years now, winter & summer, dry and mud. Shiny chain every time. Just needs a wipe when muddy or quick pass with a hose if bad. Never need chain cleaner aside from first fit (and even then I now run the factory lube for a while until it's done then just stick Squirt on).
Says about not letting it get below 0 degrees, but it's rarely that cold in Surrey and I've ridden in sub-zero snow with the stuff and still no problem.
Apply after every ride. Buy the big "shop" bottle. Better value and spout is longer / easier to apply. Also, apply a good 5 mins before riding and I apply it to the inside of the chain and spin the chain for a bit. Key is to get into the rollers. The surface isn't that important (which is why wet lube is shit as it sits on the surface and sucks in dirt).
I do 60 miles rides with the stuff no problem.
Currently using Smoove after using Squirt for the last 8 years.
I'll be changing back once the bottle is empty.
ProGold Prolink in summer, and the thicker ProGold Prolink Xtreme in winter.
Weldtite TF wet
Muc Off dry
Got both cheap in 1 litre bottles and both work very well
Squirt, no black mucky drivetrains. ALso lasts pretty well in the wet, 30 odd miles with no noise.
Another one for Squirt, if applied correctly it works in all conditions.
And Squirt > Smoove?
Purple Extreme – excellent stuff. Just make sure you apply it post-ride ready for the next ride rather than pre-ride so it has a bit of time to dry out.
Good tip.
I could pee better chain lube than Squirt and it would last longer, 30 miles?? A ha ha ha ha ha.
Always find it hilarious that people think that 30 miles is good mileage for a lube application.
Tried Squirt, properly following instructions and found it awful. Definitely the marmite of chain lubes. Same with Purple extreme.
Currently happy with Muc Off dry after picking it up in offer in Aldi last winter. Strikes a good balance between lasting a good few rides without getting too manky. Only real downside is that it tends to build up on jockeys if you over apply and needs scraped off with a screwdriver.
Still putoline here. And epic ride any time I need anything else (ie topups when I'm away on holiday or something).
I could almost drink it. Trying it for the first time. Does it leave things clean (fed up with the filth Finish Line leaves behind)?
Really? You must be easily pleased.
I am mildly amused that some people are proud of how long their pan-fried concoctions go between applications, but it doesn't even raise a smile.
I just re-lube with the appropriate bottle before each ride, job done.
No. Cassette and chainrings will eventually gunk up, even if you are being careful not to apply too much and giving it time to set. On the upside, it lasts a long time, even in wet conditions.
Quite. I can only imagine that they must be carrying around a bottle of the stuff for replenishment en route.
Its just nice to not have to lube the chain everytime you go out and not to have to take lube on a two week tour!
I look at my bike, see the chain is still well lubed and clean and go out
Haven't done my commuter this year yet - its still fine from last years application
lube the chain everytime you go out and not to have to take lube on a two week tour!buy a deep fat fryer to keep yer chain quiet
FTFY Brah. 😋😂
nope - I just chuck it on the stove. vastly extended life is also great
I have been using muc off dry lube but go anywhere near water and it's gone halfway around a 30 mile ride .I have got a bottle of tru tension bananaslip tungsten to try just wondering if anyone has given this a go yet?
2 stroke oil, remove chain and clean thoroughly in a bottle of white spirit, hang up to drip dry then leave overnight in a litre of 2 stroke oil hang up to drain off and wipe clean, good for a 4-5 rides.
I want to try the putoline but I have nowhere to heat it and weve just had a new oven, my mrs would have my testes on a fork if I used that.
cheekyboy - deep fat fryer or camping stove?
Want one treated post it to me and I will do it for yo to see if you rate it - most of us do but a couple do not
PM me if you want to take me up on it
