What blind bearing ...
[Closed] What blind bearing puller for small (8mm ID) four bar linkages?
As about, anyone know where i can get a small blind bearing puller to do seat stay bearings on FSR bikes?
Thanks
Posted : 20/12/2011 1:26 pm
 Del
rawlbolt or similar. proper blind bearing pullers cost ££££
Posted : 20/12/2011 1:29 pm
You shouldn't need one. In between the bearings is a threaded bar that the clamping bolts screw into. Screw a long M6 (or M8) bolt into this and tap it, and it should push the bearing out. Then do the same from the other side.
Do not wang it with a hammer. Tapping should be enough.
Reassemble with lots of grease to help waterproof the bearings from the inside
Posted : 20/12/2011 1:35 pm
rawlbolt
^ genius!
 Del
ithankyou. 😛
Posted : 20/12/2011 1:41 pm
This works well if you don't want to spend too much
Posted : 20/12/2011 2:19 pm
On a related subject I've got a blind bearing puller set but the collet for 8mm has bust. Anyone know where I can get a spare?
Posted : 20/12/2011 2:51 pm
How well does the rawl bolt work?
Posted : 20/12/2011 6:35 pm
Very well.
I used to use them for changing wheel/swingarm bearing on my MX bikes.
Drop the bolt into the bearing, tighten it up and just tap the bearing out.
Posted : 20/12/2011 6:42 pm
 nuke
Like the idea of the Rawlbolt method but can't seem to find a Rawlbolt with the correct width for an 8mm ID bearing, 12mm seems the smallest size. Anyone know if smaller are available?
Posted : 27/01/2012 4:21 pm
Pierre I emailed the manufacturer (franklin) of mine, as mine came with a bent collet, but unfortunately the answer was not cheap (for me anyways):
Part No. 19762 15-19mm BEARING EXTRACTOR 913D cost price £ 29.75 + vat - carriage paid witin the U.K
EEK! I only paid £50 for the puller...
Posted : 27/01/2012 4:31 pm
 nuke
[i]Yes - usually availbale in much smaller sizes[/i]
Hmmm, I should have looked at not just [url= http://www.rawlplug.co.uk/index.php?option=com_content&task=view&id=20&Itemid=25 ]Rawlbolt - Loose Bolts[/url] as their hole diameters are 12mm min. Still got to be pretty narrow though and the bolt itself will probably have to be M6. Time for a trip to the local DIY store.
Posted : 27/01/2012 4:59 pm
 nuke
Del - Member
Excellent tip Del...worked a treat: http://singletrackworld.com/forum/topic/sooooo-hemlock-owners-any-tips-to-shift-these-bearings
Posted : 01/02/2012 12:18 pm
You can also Hydraulic blind bearings out, great for small needle roller bearings like Crankshaft spigot bearings (Where the gearbox input shaft runs on a RWD car gearbox)
Pack the void and the centre bore of the bearing with grease.
use a shaft in the centre of the bearing
Tap shaft through bearing
Shaft acts on grease
Grease being non compressable, forces bearing out from behind ;o)
No risk of damage that way either 😉
HTH
Dom
Posted : 01/02/2012 12:27 pm
