What bike would you...
[Closed] What bike would you like to see built?
From another thread, I'd love to see a short, short travel FS BFe with a pivot about the BB shell like the old Commie Absolut SX so you could run it SS easily if you wanted. Basically an older shape BFe275 with a [i]smidge[/i] of rear bounce like a 4X or slopestyle bike. And a bottle cage mount [u]in[/u] the front triangle.
Posted : 17/10/2017 11:31 am
once I've got through enough of the ones they do I'll let you know
Posted : 17/10/2017 11:32 am
short travel geometron for 27.5+
Posted : 17/10/2017 11:33 am
You want a heavy, short travel FS that pedals really badly?Okey dokey.
Posted : 17/10/2017 11:39 am
Quick release, non-boost, lightish 26 or 29 hardtail with modern geo.
Basically, a slightly slacker Mk1 Soul would be perfect.
A lighter tubed version of the Specialized AWOL in nicer colours.
No other changes.
What the Sequoia should have been.
A disc specific versions of the Spa Tourer/Audax with room for bigger tyres.
And again, different colours.
Posted : 17/10/2017 11:47 am
Do-it-all Adventure bike on the racey feel side
Plain nice colour (orange please)
Roundish tubes
Dropper-capable
Hydro cross-tops
700x40c clearance
1x
£1600
Posted : 17/10/2017 11:48 am
Rorschach - You want a heavy, short travel FS that pedals really badly?Okey dokey
Oval ring and better pedal technique will fix a lot of that. BB pivot bikes were all the rage when shock technology was a bit rubbish, its all moved on since then.
Starling Cycles do a BB pivot short travel ripper.
[url= http://www.starlingcycles.com/beady-little-eye-proto/ ]http://www.starlingcycles.com/beady-little-eye-proto/[/url]
Posted : 17/10/2017 12:00 pm
Carbon Short travel, DW-link 29er with slackish HA, short chainstays, 460-470mm reach, threaded BB and properly sorted details, I.E cable routing, lifetime warranty on bearings, boost axles etc. Ibis ripley is close but just sooooo short, which is a crying shame as I loved my Mojo HD.
Posted : 17/10/2017 12:01 pm
And they were pish then.Throwing a load of LS damping at it does'nt alter the lack of anti squat or absence of any chain growth (both quite handy for pedaling efficiency)
Posted : 17/10/2017 12:09 pm
Ooooh... I need to sell some stuff.
have you ridden a geometron Rorschach ?
Posted : 17/10/2017 12:13 pm
They make that, in Ti, and the Steel version is on the way...knowing Spa though it'll still be black 🙂
OP - was going to point you at Starling but thepodge beat me to it
Have you looked at the DMR Bolt? might suit you as it sounds like exactly what you want but with a bit too much travel, so with a shorter or travel limited shock it could be everything you're after... 😉
I had a couple of Kona A's over the years (one stolen, one snapped), and I absolutely loved them, with only 75/80mm of travel and a decent amount of LSC it was ace, All the joy of a single speed, but with the added bonus of being able to carry more momentum than normal and climb some stuff that would have a HT losing traction.
They weren't perfect for sure but I really really miss the Kona A 🙁
The last time I started down this path I ended up having something unique built by BTR, it was (still is) ace but if I were to do it again I'd make some small changes...argh! Don't make me start thinking again, my bank balance won't like it!
Posted : 17/10/2017 12:14 pm
I think matey-boy was posting at me, sofaking.
ah ok kayla1, two of the three points he raised can be said about the mojos
Posted : 17/10/2017 12:16 pm
From another thread, I'd love to see a short, short travel FS BFe with a pivot about the BB shell like the old Commie Absolut SX so you could run it SS easily if you wanted. Basically an older shape BFe275 with a smidge of rear bounce like a 4X or slopestyle bike. And a bottle cage mount in the front triangle
So basically a DMR Bolt? No bottle cage mounts though.
Posted : 17/10/2017 12:20 pm
sofaking - Member
This, without the plus (and price tag :D).
Posted : 17/10/2017 12:27 pm
fathomer - This, without the plus (and price tag :D).
MDE Damper with their custom option?
[url= http://www.mdebikes.com/damper-650b-2018/ ]http://www.mdebikes.com/damper-650b-2018/[/url]
[url= http://www.mdebikes.com/rider-tuned-geometry/ ]http://www.mdebikes.com/rider-tuned-geometry/[/url]
Posted : 17/10/2017 12:41 pm
What do I want?
An affordable (say frame for ~£400) Long/low/slack 29er HT in Carbon with two sets of bottle cage bosses and swap-outs so I can run QR/142/148 hubs as I see fit, oooh and externally routed gear/brake lines...
Posted : 17/10/2017 12:54 pm
Orange 4 with a usable bottle mount.
Posted : 17/10/2017 1:02 pm
I just want an Airdrop Edit Coil. That'll do nicely thanks.
Posted : 17/10/2017 1:03 pm
sofaking - Member
Pretty sure he meant the BB pivot BFe suggested in the OP's post
Posted : 17/10/2017 1:07 pm
Yup (Geometron has AS around 120% and quite high pedal kickback and does'nt use a concentric BB pivot....so I'm not sure what your point is).
And I've ridden a Kona A and Bass.And a Cove G-spot.And a Commencal Absolute Sx.I always liked the [i]idea[/i] of BB pivots.
Posted : 17/10/2017 1:17 pm
Sort of, still a smidge too much travel though, #moononastick...
Posted : 17/10/2017 1:24 pm
Easy - a light carbon XC race bike with clearance for 2.6" tyres and a 66-67°HA, as to me, this is what a 'trail' bike should be, fast and efficient going up, and a little bit more confidence inspiring going down.
I'm pretty sure we will see one of these made over the next couple of years.
Scott have come very close already with the new Spark (not RC).
Posted : 17/10/2017 1:39 pm
Easy fix with shock mods though.
Posted : 17/10/2017 2:03 pm
Spearfish with a slacker head angle and boost ready. And not priced at mental money.
One thing this thread shows is that we all want different things - can't please all of the people all of the time!
Posted : 17/10/2017 2:07 pm
That's awfully like a Pivot Mach 429 trail (116mm) or SL (100mm) if you can stomach a press fit BB (mines been fine)
All y'all who want steel hardtails that don't exist, give a frame builder a ring, make it happen.
The reach on the Pivot is super, super short though, a good 40-50mm shorter than I'd like in a Size large and there is no way I'm having a PF BB again. There are a few that get close, the new Evil Following is one, but I'm still wary of their frames holding up and the other is Transition Smuggler but they haven't done that in carbon yet. Was really hoping Whyte would do a T129 carbon this year but now it's gone altogether!
Posted : 17/10/2017 2:26 pm
More singlespeed bikes. Tensioners on normal bikes suck. Couldn't give a rats ass about bolt through dropouts I'd rather have track ends!
I'd really like an SS fat bike designed around 4" tyres, slammed chainstays and bent seatube, 450 reach, 67 head angle.
Basically my current Fatty with slightly better cornering.
At On-one prices.
y'all
And I don't like Country or Western.
Posted : 17/10/2017 2:34 pm
@kayla1
https://www.rosebikes.co.uk/products/bikes/mtb/dirt/the-jester/
Why would you want steel? it's always heavier. No stronger really. but repairable I suppose. do you break a lot of frames?
And why would you need waterbottle mounts on a bike you won't climb (much) or do long rides on?
Just drink a pint of water before you ride. and have another at the end.
Don;t know about the OP, but I feel the difference in weight of steel on the frame much less than I feel the difference in weight of my wallet with carbon.
Bottle cages are handy things, whether you use the regularly or not it's an option that's nice to have.
Posted : 17/10/2017 2:45 pm
er..
The bike I linked to has an Aluminium frame and as a complete bike is a similar price to a steel Cotic full sus frame.
Posted : 17/10/2017 4:08 pm
26" though init?
Posted : 17/10/2017 4:10 pm
Nice classic STW thread, people say what their bike desire is and other people patronise them and tell them they're wrong!
[url= https://www.transitionbikes.com/Bikes_Smuggler.cfm ]Transition Smuggler[/url] or [url= https://robotbike.co/r130-frames-calculator/?v=79cba1185463 ]Robot Bike Co R130?[/url]
Posted : 17/10/2017 4:25 pm
Stronger, cheaper, lighterer init?
Posted : 17/10/2017 4:31 pm
Can't speak for the OP but for me I take a camelbak on longer rides but for short blasts on a fun bike a water bottle cage is great for carrying a small amount of water, and leaving it by the side of the trail when sessioning something fun.
Posted : 17/10/2017 4:38 pm
You asked [i]a [/i]question, I gave [i]an [/i]answer.
If you were asking specifically about that bike that's different, I'm not the OP...hence my answer being about carbon, not Alu, and not mentioning anything about specific bikes/prices.
Posted : 17/10/2017 4:39 pm
I asked Kayla the question. Hence the "@Kayla1" before said question.
I think I see now why you're so attached to sookin' a bottle. Amedias. I'm not in the slightest interested in what bike you'd like or why.
Posted : 17/10/2017 5:04 pm
I like only having one bike so it'd have to do everything from popping to the shops, to XC mincey rides out for Sunday dinner, to local DH races and a bottle cage is handy- I don't like carrying a backpack if I don't have to. It's a 'what if' thread, why do I need to explain myself? 😆
Posted : 17/10/2017 5:40 pm
I'd like a fixed wheel bike with disc brakes. With space for reasonable road/touring tyres, and mudguard and rack mount. Preferably aluminium frame, carbon forks.
Basically an improved version of my Pompino. Something like a fixed version of the Planet X London Road or Sonder Camino.
Posted : 17/10/2017 5:41 pm
You don't! Not if you don't want to. Might seem a bit odd being your thread though. 😛
My interest in why you want the things you stated only comes from having many "unsuitable" (mainly 4X, dirtjump and slopestyle) bikes over the years myself. and set them up to be able to do everything from all day XC, ride up DH to DJ/4X/Stunting on without compromise.
Rorschach has it pretty spot on in his summary of what you said you want. let go of the eccentric BB and Steel fettish and you could be onto something pretty wonderful though. 😉
Posted : 17/10/2017 6:27 pm
I'd like to see these in production:-
Because of (among other things) this:-
Boost can get F****d
Posted : 17/10/2017 9:31 pm
amedias - Member
The black is at least better than the green or the red.
I'm a fan of CT's designs, and I recall something about new models on the CTC site.
Really looking forward to seeing those.
I had a ride on a prototype Disc Tourer (Wayfarer?) a couple of years ago, they had a few sizes in.
Lovely bike, but they had decided to stick with V brake mounts as well, which limited tyre size.
They offered me the demo bike at a very decent price, but I decided on something else from them instead.
Think that was the first prototype, no idea where they are with it now!
Posted : 17/10/2017 10:10 pm
Kayla:
How about the Rotec Revert (no bottle inside the frame though)
Or the Starling Beady Little Eye if and when it ever actually exists
Posted : 17/10/2017 10:21 pm
A 29 inch aluminium soft-tail with 120mm forks and 68 degree head angle which will take anything between 29x2.2 up to 29x3.0 tyres and ship with different dropout inserts so you can adjust BB height accordingly. Cinelli will do the paint job.
Posted : 17/10/2017 10:47 pm
There is (or at least was) an EBB version of the pinnacle Arkose that could be used geared or SS (or fixed).
Posted : 18/10/2017 8:12 am
Honestly can't think of anything that is not already in production that would fit any need i have. I'm a simple boy and they're clever chaps....
Posted : 18/10/2017 8:14 am
OOOOH, that Millyard bike, yes please.
Didn't Dirt ride it, claim it was the best bike ever and then find out it only had 100mm travel?
Posted : 18/10/2017 12:11 pm
thepodge - Member
Not sure I'd class 160mm as short travel, though I may have missed that this can be altered as part of the custom option.
Posted : 18/10/2017 2:16 pm
Sorry, kind of missed the short bit.
Carve is 140mm, boulder is 130, I guess it depends how short is short.
Posted : 18/10/2017 2:23 pm
A cannondale rush carbon like my 2008 one but with 29 inch wheels, slightly slacker and a 31.6mm seat tube.
Posted : 24/10/2017 1:42 pm
 Bez
I'd like a CX/gravel/touring/whatever bike, with EBB or sliding dropouts, 3 speed gear hub with a 200% range, discs, clearance for 29x2 tyres with guards, a Headshok fork and a Scalpel back end, and remote lockout. I think 🙂
Posted : 24/10/2017 4:19 pm
