What are these thin...
[Closed] What are these things for...
...3 thin washer type things that came with my new rotor? Like a big but thin chain link. Do they go between the rotor and the hub?
Posted : 04/12/2014 10:47 am
They go under the rotor bolts, between the bolt heads and rotor.
Guess they are to stop the bolts coming loose?
Posted : 04/12/2014 10:49 am
answer is in this thread somewhere...
http://singletrackworld.com/forum/topic/anyone-know-what-these-are-for
Posted : 04/12/2014 10:52 am
They go under the bolts, which then need to be done up in a certain order to prevent you mashing them up (should be on supplied instructions). It's to prevent the bolts from coming loose, shimano have a bit of an obsession with that, they used to supply a thin cable to wrap around caliper bolts for the same reason...
Posted : 04/12/2014 10:56 am
Lawyers Washers.
There should be a little sprung tab on the the washers that locks on the triangular head of the bolt when they are done up.
Posted : 04/12/2014 11:01 am
It's not just a sprung tab, you're supposed to fold them over the triangular corners of the bolts.
Posted : 04/12/2014 11:02 am
I think they have changed Ben. The first version was like that, the later ones are self locking.
They no longer come with the 'flower' back plate either.
Posted : 04/12/2014 11:04 am
Ah. Silly idea anyhow ๐Ÿ˜‰
Posted : 04/12/2014 11:05 am
Too true.
Posted : 04/12/2014 11:06 am
Magic thanks. Came with round bolts so no folding.
Posted : 04/12/2014 11:32 am
does anyone actually use these things? I've always binned them (I do use threadlock).
Posted : 04/12/2014 11:34 am
Nope
And I dont use the little plastic clips that come with caliper bolts either.
Mad I am
Posted : 04/12/2014 11:38 am
bin them and apply thread lock
Posted : 04/12/2014 11:50 am
I think Shimano should make these for rotor bolts.
Posted : 04/12/2014 12:11 pm
