What are Small Bloc...
[Closed] What are Small Block 8's like on the road?
 AB
As above
Posted : 09/08/2009 8:14 am
 PJay
Ok. I found them a bit draggy (1.95") compared to the conventional semi-slicks I was using, but they're certainly usable. I'm currently trying Panaracer Racer XCs as an on/off road tyre and my experiences are pretty positive to date.
Posted : 09/08/2009 8:17 am
They are not designed for the road so of course they are draggy. IF tarmac is important, get some semi slicks.
I love my SM8's, they are so much better than they look!
Posted : 09/08/2009 8:28 am
 AB
Not intending on buying them for road use, but there will be a bit of road required, so wanted to find out what they were like.
Posted : 09/08/2009 8:46 am
I found them more draggy than normal knobblies (Ignitors). There's no central ridge of any form, just rows of horizontally aligned small blocks, this makes for a very draining ride on good road. On hardpack/dust they are fine, because the knobblies sink in leaving a flatter roll profile.
Posted : 09/08/2009 8:55 am
Like Sinatra says they're not designed for the road.
They have a low profile and there's a 'lead in' slope to each row of blocks so they drag a lot less than most. They'll drag more than a slick but less than something like a super tacky Swampthing or other big knobbly you care to mention.
It's pretty subjective but for an [i]off road[/i] tyre they're ok on the road (and pretty damn fast off road)
Posted : 09/08/2009 2:52 pm
I agree, I had SM8 on my 29er ( thus uniting 2 current threads ) and found them fine on the tarmac for an offroad tyre. I use the 29er for rides from my back door that are a mixture of backroad tarmac, bridleway, Dalby trail centre and moorland singletrack and they were fine in the summer/autumn last year. Subsequently swapped to Panaracer Rampage which have a beefier tread and thus have a slight advantage in the mud of winter and indeed this summer and haven't swapped back yet although I have got a set of 26 inch SM8's going on the other half's bike.
Posted : 09/08/2009 3:43 pm
what about semislick on back sm8 up front - some of the charge 4x bikes run this...
Posted : 09/08/2009 3:45 pm
A few of us use them on out commute to the trails.
Personally I find Nevegals drag too but are fine on the road to the trail
Have you tried Maxxis TT-bit of a dry tyre only.
Posted : 09/08/2009 3:48 pm
Certainly wouldn't say they're draggy at all, they're faster than any other actual usable offroad tyre I've ever used, and not drastically slower than my old road tyres (which have a slight tread, not full slick in the centre). I doubt you'll find anything faster on tarmac that doesn't compromise offroad (I'm really confused by the Maxxis Ignitors comment though, I found them fairly slow on road, a lot slower than the SBs)
It's true they don't have a solid centre roll, but the second row of blocks evens that out a lot- you don't just "cog" along on the middle row. Though like some other tyres they seem to get slower as you up the pressure- they're faster at about 35 than they are at 60, because at lower pressures the load is more spread out while at higher pressures they sit more on the central row, I think.
Posted : 09/08/2009 3:52 pm
