Just got above, chart on side packaging would indicate about 160psi for my weight; by comparison Krylions would be about 110-120 for same size tyre; why such a high pressure, does anyone pump themn up that hard?
ta
I'm pretty sure mine say 116 psi max on the sidewalls!
Anyway usually between 90 to 110 psi depending on how much comfort I fancy. I'm around 75kg just to put it into context.
It`s the chart on the packet that says 160psi....!your pressures sound much more sensible 🙂
110 psi & 14st, 160 sounds pretty high. Great tyres btw!
160 for a tub maybe, wouldn't go much above 120 on any clincher tbh........
I tend to go 100 for dry rides & around 90 if it's wet
Fully agree with uplink.
160!!! are you sure ?
Ride between 80 and 100, i'm 10.5st
no not sure 🙁 ---so will stick with pressures suggested here ie 100-120 lb
