Have just bought a post mount fork and need to fit my existing brakes, which are Magura Marta SL IS calliper with 160mm disc.
I have seen an adaptor on CRC that states "to mount a 74mm post mount caliper to a 51mm International Standard fork mount to accomodate a 160mm disc", but this is the wrong way round for me.
Cant work out whether I could still use this though, or if I need a different adaptor...?
If the latter, can anyone point me in the direction of the correct adaptor and where to buy?
Many thanks.
You may have to go +20mm.
I don't think a straight post to IS 160mm exists
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]One of these[/url]
But you will need to go +20mm on your rotor size.
Out of stock, but Hope stuff is available from everywhere!
Thanks for the advice - so it looks like I dont need a Magura specific adaptor, but will need to swap my 160 rotor for a 180...?
Yes, you'll need to go up 20mm to the bigger rotor - you'll not get a 160mm adaptor that'll fit for your combo alas.
Don't get the A2Z Keep 160 Adaptor. It doesn't work. I got one last week, but fortunately Wiggle are very good with their returns. I have now fitted them using a Hope +20 adaptor. This was for fitting old Hayes Sole onto a Manitou Drake (on a Hard Rock Sport).
