What 60-70mm stem w...
[Closed] What 60-70mm stem with about 10-15 degrees rise?
Hi
Am after something like the above.
Currently using a 70mm Hope with 25 degrees rise but it's just too much.
What's out there that's good?
Steve
Posted : 10/01/2016 3:23 pm
Could you not get a normal stem and a bar with more rise? Would probably look a bit better as well!
Posted : 10/01/2016 3:43 pm
Easton do a 17 degree 70mm one. Specialized used to do an adjustable 8degree / 16 degree one in 60mm and 70mm. Not seen many others about.
I have the same problem OP. Currently using a Ritchey 30 degree stem and would like to drop it by a centimetre or two but finding it hard to find the right one.
Have a little play on a stem calculator if you haven't already. Remember that if you lower the stem angle the reach will increase.
Posted : 10/01/2016 3:47 pm
Hi
Thanks for the replies
Already using 30mm rise bars and don't want to go higher.
The problem is the steerer length on the fork is a bit short so I can only use the stem with a 5mm spacer so that if I have a flat stem and my brake levers where I want them they catch on the top tube if the bars spin round.
To get round this I use the Hope 25 degree rise stem.
I have a little leeway with the brake lever position which is why I thought I'd lower the rise a touch and see what happens.
I suppose I could always replace the forks with ones with a longer steerer but that is a more expensive route.
I can live with it as it is- just an experiment really
Steve
Posted : 10/01/2016 5:03 pm
Race face turbine 60mm with 10° rise is a nice bit of kit.
Posted : 10/01/2016 5:18 pm
Hi
Turbine is 6 degrees but DH/AM is 10 degrees.
That may be the best option
Steve
Posted : 10/01/2016 5:49 pm
