What 40mm ID rim fo...
[Closed] What 40mm ID rim for 29 x 3.0 tyre?
I'm currently on a Stans Hugo (54mm) rim and thinking of getting something less huuuaaage. Got a Minion DHF 29x3.o on the way - which needs a minimum 40mm rim.
Was gonna go Stans Baron mk3, but theyre only 35 ID.
What 40mm rims are out there?
Posted : 16/01/2020 12:25 pm
WTB Scraper i40?
Posted : 16/01/2020 12:27 pm
You don't need 40mm internal for DHF 3.0; I am running on 35mm and it's fine. Having said that I reckon 40mm is probably sweet spot between weight and tyre profile.
Posted : 16/01/2020 12:31 pm
Yeah, I'm aware I wont die on a 35, but as you say, 40 is the sweet spot. I like to run the pressure quite low (like 11 psi). I think Stans do a wider Major, but Ive never seen one for sale??
Hadn't heard of a Scraper yourguitarhero, so Ill check that out right now.
Posted : 16/01/2020 12:35 pm
I just built a wheel around an easton arc 45mm rim for a 3.0 surly dirt wizard
Is 40mm not on the small side for 3.0?
Posted : 16/01/2020 5:54 pm
Arc is a good deal lighter than the Scraper IIRC.
Posted : 16/01/2020 6:00 pm
DT XM551 are excellent, 40mm internal, decent weight, tough as old boots (I went through a lot of plus tyres before getting the hang of pressures, but no dings yet)
Posted : 16/01/2020 6:15 pm
Does it come in 29er?
Posted : 16/01/2020 6:38 pm
Where dya get that from wzzz? Cant see them FS in UK.
Posted : 16/01/2020 7:46 pm
W.T.B. K.O.M. light or tough
Posted : 16/01/2020 7:53 pm
yourguitarhero mentioned the Scrapers above. I hadn't heard of them before, and there's a light or a tough option?
Posted : 16/01/2020 8:01 pm
Yes, KOM come in light OR tough, I have a pair of tough on my Krampus in i40.
Posted : 16/01/2020 8:24 pm
Ive just found them on CRC.
614g Light, 671g Tough.
I love to save weight but on a rigid, I think Id need the tough for peace of mind.
Posted : 16/01/2020 8:31 pm
Scored a pair new unused on ebay for £40, seems they may have stopped doing them.
Posted : 16/01/2020 10:42 pm
