What 29er XC tyres ...
[Closed] What 29er XC tyres are working well TLR
I have Bontrager TLR rims, so I'll need to get the strip/valve and Super Juice. But it's not like when I used to have a proper UST set up where stuff just worked like you knew it would.
Fave tyre is the Racing Ralph, but I'm finding the 29er isn't too tyre fussy.
Posted : 23/02/2014 9:29 pm
 mboy
Try the Maxxis Ikon
Faster and grippier than a Racing Ralph IMO.
Specialized Ground Controls are quick and grippy too, and cheap.
Any UST/TLR tyre should work straight away, but with rimstrips many normal tyres work tubeless too.
Posted : 23/02/2014 9:34 pm
All of them work fine, the only problem is the part with the beating heart.
Pick your tyre, learn how to tubeless a tyre properly - check out some of my replied to threads - I give some very good tips from a lot of experience with loads of different tyres, because I used to buy lots, because I was a moron.
Seriously, pretty much any tyre will tubeless with minimal effort. f you're doing it right, you should be able to get a tyre on a rim, sealed at less than 20psi.
Posted : 23/02/2014 11:00 pm
Rocket Rons are a great all rounder IMO. Perhaps a little fragile if you ride a lot of rocks.
Posted : 23/02/2014 11:06 pm
I really like Geax tires and they go up well Tubeless
Saguaro for general and dry, Gato for wet, Goma for Trail
I did like Conti X King but found them too expensive and i had sidewalls rip even on the Protection version
Posted : 23/02/2014 11:16 pm
anything schwalbe evolution seems to go up easily and stay up in my experience
Posted : 23/02/2014 11:17 pm
IKON's are fast and grippy but they are really delicate. I gave up on mine after having far multiple slices going right through the tread
Posted : 24/02/2014 12:17 am
 mbl1
I bought an Ikon and tore a hole in it after 10 miles. By comparison I have never done this to any other tyre. It could be bad luck, but the sidewalls really are thin.
I was quite surprised how grippy the Maxxis Crossmark is.
Posted : 24/02/2014 7:41 am
 mboy
There are different versions of the Ikon, but the super light versions are very thin indeed. I'd not really recommend those, but the thicker (preferably EXO sidewall) versions. They are remarkably grippy for their speed though.
Likewise, but if anything, the Ikon is even grippier!
Posted : 24/02/2014 5:14 pm
Classic replaced tube trailside yesterday, just been out to the bike to find front and rear flat.
Multiple thorn holes in all tubes.
Tubeless or Slime Tube for this ongoing problem, Buckthorn? everywhere 200mm nail like thorns.
Posted : 24/02/2014 8:34 pm
 gee
Racing Ralph snakeskin. Just stick them on and never change them round here irrespective of weather.
GB
Posted : 24/02/2014 8:37 pm
Ralph Snakeskin are my favourite too, although I currently have Rocket Rons on because the weather has been so bad.
Ron's are better in the mud, but more skatey on rocks and trail centre type surfaces.
Posted : 24/02/2014 8:50 pm
I really liked the Ikon 3C exo set up tubess stans fast and grippy no problems with side walls, not so good on wet grass , but not really a winter tyre.
Posted : 24/02/2014 8:54 pm
Specialized ground control s works is my favourite tyre at the moment, great all rounder and super light
Posted : 24/02/2014 9:29 pm
