What 29er frame in ...
[Closed] What 29er frame in gate proportions? 😉
Ok ok so I have succumb like a sheep and I want to build up a 29er XC hardtail machine!
I am 6' 6 36" inside leg so it must be huge 😉
Definitely not ss and will probably run with a sid/reba.
Bonus points for:
Cheap! sub £400
Bright coloured!
High bb height!
cheers
Posted : 24/02/2014 10:25 pm
 bol
Solaris in xl. Meets all criteria I think, well, ish.
Posted : 24/02/2014 10:27 pm
36" inside leg here. 20" frames fit me fine. - it's not even a particularly wierd size for a 29er.
Posted : 24/02/2014 10:30 pm
There was a chap a week or so ago selling a pink on one scandal in 20" which comes up pretty long.
Might be worth a search.
 LoCo
Would have though the main issue would have been reach at 6.6.
At only 6' 3" and 34" leg 20" fit me fine.
Posted : 24/02/2014 10:38 pm
Surly Ogre.
Just build one of a mate who's 6'8''
(edit) even he said it looked BIG!
Posted : 24/02/2014 10:41 pm
6'5" here and ride a 21" inbred 29er in bright orange. Frames are £150. The other option that springs to mind is a solaris. They're selling off some XL bright blue frames cheap. So far I've managed to resist.
Posted : 24/02/2014 10:49 pm
Bikescene are doing Spesh Carve pro frames for £270 at the mo, they come in HUGE..
Posted : 24/02/2014 10:51 pm
A 20 inch frame with a 36 inside leg and 6'6" is way too small unless you the OP plans on a very low saddle height, a riser stem, a stack of spacers or a 10cm saddle to bar drop. 21 inch Solaris, Niner, Highball would be great.
Posted : 24/02/2014 10:54 pm
 ton
22'' karate monkey was too big for me at 6 foot 4'' with a 33'' inside leg.
huuuuge thing.
Posted : 24/02/2014 10:56 pm
not pink 😉
googling Solaris....
Posted : 24/02/2014 11:02 pm
Yum! If only the bright green were reduced too, may have been a winner!
Posted : 24/02/2014 11:04 pm
120mm on a 29er feels about the same as 140mm on a 26er yes?
Posted : 24/02/2014 11:05 pm
Bright Blue XL Solaris are on offer at the moment.
There aren't any Bright Green XL ones left.
Yes, the "feels like it has more travel" thing is sort of true, fork wise.
Posted : 25/02/2014 12:51 am
 mboy
I've got a customer who's 6ft10, makes his 23" Spesh Rockhopper 29er with 400mm seatpost at max extension, and riser bars on it, look like a BMX! Haha.
MrTall off here rides a Kona honzo 20"Long (they do that rather than make a 22" I think for stand over reasons) that at 6ft7 seems to fit him quite well. He's got the world's longest legs though!
Stanton Bikes new Sherpa frame is going to come in a 21" size, with a VERY long top tube. Dan told me he's designed it to fit a mate who's 6ft6 thereabouts and long of limb. Gotta wait a few months yet though!
21" Inbred 29er (or a Scandal) would be the obvious cheap choice. Geometry is a bit too steep though IMO (I owned one), needs updating.
Solaris in an XL looks a bargain at the moment at 25% off, should be big enough at a push too.
As for forks... SID's really are for lightweight super skinny race whippets. They're flexy and I wouldn't recommend them to most people, at your height (even if you're skinny) you're going to find them quite a flexy proposition. Reba's are better, but still not the stiffest. I'd look at something like the cheap 2012 Revelations on CRC right now as although still a 32mm fork there's more material in them, or the X-Fusion Slide. Both forks are highly adjustable travel wise, noticeably stiffer than a SID or a Reba, and don't cost the earth. Running one of each right now and impressed with both.
Posted : 25/02/2014 1:18 am
Aren't current SIDs and Rebas based on the same lower and crown? Both as flexy/stiff as each other? Revelations/Slants good suggestions.
Posted : 25/02/2014 12:26 pm
Cotic are doing XL Solariseses cheap ATM.
Posted : 25/02/2014 12:33 pm
I had an XL Solaris.
At 6' 3'' I found the fit good in all respects except standover. Felt a little too close for comfort.
[b]My XL Solaris:[/b]
I had a 21 Inbred too and found the fit again really good but the standover was as above .... too close for comfort!
[b]My XL Inbred[/b]
I would have though both would be a good fit for the larger gent 🙂
That said after a number of exchanges of emails with Dan @ Stanton bikes I shall be going with a 21'' Sherpa 🙂
Posted : 25/02/2014 12:52 pm
^^ ... Mark, did you have a preference between the Inbred and Solaris ?
I'm 6'3 with a 33 inside leg and am tempted with the Solaris offers at Cotic, esp as they can run 120mm forks.
Posted : 25/02/2014 3:06 pm
I liked both, but they were markedly different.
The Inbred, despite its heft, flew along and [i]despite[/i] only having 80mm of travel felt really planted.
The Solaris was built as an all day bike. Flows, Ardents dropper etc.
I thought it stiff for a steel frame but then I thought it accelerated much quicker than the Soul it replaced that was far flexier.
I would have like to have tried a 120mm fork but that really would have compromised the stand over clearance.
With a 33'' leg and a 120mm fork I would want to be wearing platform shoes to avoid damaging the boys 😆
Posted : 25/02/2014 3:19 pm
