Weird chain problem
[Closed] Weird chain problem
Well, it's not one I've had before anyway.
With bike on stand, it all works fine.
When out riding, if I freewheel, the rear derailleur moves forward (long up raises up towards chainstay) and top line of chain goes all slack, handing down between chainstay and wheel.
Is this a form of chainsuck I've not encountered before? Stiff link?
What I don't understand is why it's fine on the stand but not on the road.
Any advice? I've done a quick Google, didn't really find much, thought I'd ask you lot before I attempt a fettle at lunchtime. (While the long wait for my belt-driven bike continues...)
Thanks!
Posted : 18/05/2017 11:16 am
I'm guessing the freewheel bearings might need replacing?
Posted : 18/05/2017 11:21 am
yeah, the freehub ain't as free as it should be.
I'd guess bearings or a missing/incorrectly re-assembled part (eg the washer in a Hope)
Posted : 18/05/2017 11:32 am
ah, now that is very possible
so what's going on then, if that's the case?
Posted : 18/05/2017 11:33 am
I have never serviced the hub and/or freewheel 🙄
… and it is, um, 15 years old.
Will whacking some grease in somewhere keep it going for a few week until new bike day?
Posted : 18/05/2017 11:35 am
^^^ I think you have just answered your own question 🙂
Proper strip and service - the bearings may well be shot though - a freehub body isn't usually an expensive item to replace
Posted : 18/05/2017 11:36 am
Yup - thanks folks.
Posted : 18/05/2017 11:39 am
I had a similar issue - the rear axle had snapped! Same difference though, something was stopping the hub from freewheeling properly so the chain was getting snagged up. Keep pedalling! 🙂
My brother just had exactly this on an old Kona. New freehub body sorted it for £20. (Shimano).
Posted : 18/05/2017 12:37 pm
The make and model of the rear hub would be useful to know....
Posted : 18/05/2017 12:59 pm
It'a a Hope hub. Couldn't tell you the model - whatever was current in about 2001.
I think, given my abuse and neglect, it is a huge testimony to our friends in the North that it's lasted this well. And I apologise to them for said neglect.
Posted : 18/05/2017 2:43 pm
You should send it to them, labelled 'long term test complete'. They'd probably be quite intrigued to see what its like after so many years of neglect! 😀
Posted : 18/05/2017 3:07 pm
I'm confident a squirt of GT-85 in the right general direction will bring it back to life.
Posted : 18/05/2017 4:04 pm
Weird as it sounds you may well be right, you don't want too thick grease in a freehub. A liberal spritz of GT85 certainly wont hurt.
Also worth checking, the same was happening on my commuter last night when I backpedalled a little, it was caused by a partially snapped rear mech cable which put the mech enough off line to stiffen the chain, but not enough to make it skip.
Posted : 18/05/2017 4:13 pm
Mine did that, when I snapped the axle in my hub. But as others have said probably more likely a freehub issue.
Posted : 18/05/2017 4:54 pm
If its from 2001 it'll be an XC or a Sport hub.
They pretty much pull apart. If you go onto hope's site you should be able to find a service guide for it.
You'll probably need 2 new bearings in the freehub body and the ratchet mechanism will need a good clean and lube. If its just gummed up you'll probably just get away with a clean and re-grease.
Been riding Hope XC's for 20 years now.
Posted : 19/05/2017 9:52 am
my Mavic SLRs do this when they need a service. Should be relatively easy to do.
Posted : 19/05/2017 9:56 am
Hope stuff is effing legend isn't it?
Dismantled, cleaned out the grot, nice squirt of fresh grease - now running perfect.
Am going out for a ride 🙂
Posted : 21/05/2017 10:07 am
