Wear your helmet ki...
[Closed] Wear your helmet kids!
 Solo
[i]It's hard to see a good alternative solution that wouldn't be unbearable to wear.[/i]
Exactly !. Now add manuf/retail costs into the mix and suddenly we're transported to a place where helmet design is very different to what we're wearing today.
S
Posted : 27/07/2010 10:00 am
 LHS
Current helmets I've seen/I own, are dense polystyrene, and something as round and blunt as my head isn't going to compress it enough to enjoy any cushioning effect during an impact.
The density of polystyrene is carefully controlled and calculated to provide the best impact protection. The compression of the polystyrene provides a large deceleration during an impact event. When it approaches the maximum compression allowable by the density of the foam, the failure mechanism changes to that of fracture to further dissipate energy. Once fracture has occured the helmet has then dissipated as much energy as it can by design.
Posted : 27/07/2010 10:02 am
I haven't read all of this, as the usual suspects were present and correct early on and it's never very fruitful.
The crash occurred "[i][u]on a double step down [/u][/i]". Now I'm not sure [i]exactly[/i] what that is, but I'm confident that it is RAD to the power of sick. I'd be wearing a helmet if I was doing a "double step down", as I think 99% of us would be.
I'll still potentially not bother when I'm bimbling to the shops or doing other purely ambient and in no way gnarl things. 🙂
Posted : 27/07/2010 10:08 am
Just another anecdote, but I watched the occupant of this...
... piledriving head first into the ground after spectacularly misjudging a steep roll-in to a fire road. And he walked away from it (slightly unsteadily).
Posted : 27/07/2010 10:15 am
BigDummy, it was where one deep step followed directly after another one so the rear wheel went light as the front dropped down the first step then carried on going lighter (i.e skywards) as the front wheel dropped down the second step. I think it was one of those cases where if I'd been going a touch slower I could have saved it or a bit faster & I could have cleared it although my talent would also have run out on the second option I suspect!
Posted : 27/07/2010 10:19 am
I kinda knew that. 😉
Point is, [i]even TJ[/i] usually admits that he wears a helmet when he's doing anything seriously fast or technical with any risk of falling off the bike that's greater than the risk of tripping over while walking. As with others, I wear a good, well-fitting helmet when I'm riding hard off road, but quite often a good, well-fitting trilby when I'm riding gently around town.
Posted : 27/07/2010 10:22 am
After all this, that's what I was going to say 🙂 The foam probably flexed a bit, storing the energy and then the snap dissipated it. Have any of the posters measured the density of the foam through the helmet to see if it did in fact compress? Or are you just looking at a photo of the outside?
So let me get this straight. Are people (TJ) seriously advocating NOT wearing anything at all to protect your head in the case of an accident? I mean, if you have to headbut the ground, would you rather your head be completely naked, or wrapped in polystyrene?
Words fail me, they really do.
As for following the science Mr Jeremy, why don't you try it yourself? No scientist will want to stake his life on his 'theories', so wear a helmet just in case.
Posted : 27/07/2010 10:27 am
 Solo
LHS.
Yes, I should have written "enjoy [b]much[/b] cushioning..." rather than "enjoy any cushioning".
However, the polystyrene still isn't compressing very much, esp when forces are spread over the contact area of my head against the inner surfaces/contact points of the helmet. My skin is softer than the polystyrene in the helmet.
More often than not the crack originates from stress raisers and point loads play their part in propagating a failure, and as before, once failure occurs, the helmet ceases to protect although the accident being experienced could still be happening...
However, none of this appears to play much of a constructive role in controlling head decelleration, imo.
Do we have a "Pulse" for head impact, wearing a conventional cycle helmet.
Bet it spikes significantly just before the polystyrene fails...
Consider motorsport helmets, theres a bit more going on there, including cost and not forgetting the question/issue of comfort...
Then consider that we've all been shown the Sainsbury's/Tesco £8 specials, and there probably isn't a market for the £250 cycle helmet.
So, we pays our money.....But what is the choice ?.
S
Posted : 27/07/2010 10:29 am
Oh yay my post has resulted in a pic of naked women, who'd a thunk it 😆
 Solo
[i]So let me get this straight. Are people (TJ) seriously advocating NOT wearing anything at all to protect your head in the case of an accident?[/i]
As in my earlier post. I wear a current design of helmet.
However, I'm wondering whether it couldn't be done better, from a safety/protection performance prospective ?.
S
Posted : 27/07/2010 10:33 am
 LHS
To reduce the decelleration your head sees during an impact event the polystyrene doesn't have to compress that much. You would be surprised.
We have done a lot of work at looking at different densities of foams and different thicknesses of EPS. The results are quite wide ranging but only up to a certain optimal point. We have also looked at variable EPS density liner where the density increases as you travel through the thickness to further control the rate of deceleration.
Posted : 27/07/2010 10:41 am
Solo, by people I meant TJ 🙂 I think your approach is a good one, but helmet manufacturers have been working on this for many years, I suspect that they are somewhat further down the development road than you 🙂
You already have several options. You could get a super vented light road lid, or an MTB specific one like a Giro Xen. For more protection you could get various degrees of full-facer, or even a BMX pisspot with a thick hard shell.
However, none of this [b]appears[/b] to play much of a constructive role in controlling head decelleration, [b]imo[/b]
Yeah but in all fairness, you are not doing any research or experimentation, you are just guessing.
Posted : 27/07/2010 10:42 am
[i]So let me get this straight. Are people (TJ) seriously advocating NOT wearing anything at all to protect your head in the case of an accident? I mean, if you have to headbut the ground, would you rather your head be completely naked, or wrapped in polystyrene?[/i]
No, they're not. that's the bit that some people fail to grasp here. TJ has never said "don't wear a helmet" and has frequently said that if he knows he's doing techy stuff he always wears one.
All that some people are suggesting that sometimes it's not really necessary to wear one, and that generally people have a higher regard for the protective qualities of bicycle helmets that the evidence would suggest that they should....
Ok?
Posted : 27/07/2010 10:44 am
LHS, for whom do you work, if you don't mind me asking? Independent researcher or lid manufacturer?
Nickc - then it would be a classic case of TJ arguing for something utterly bleedin obvious whilst appearing to argue something controversial with the result that everyone gets wound up.
I think he does that because he doesn't understand people very well. If he really thinks that WE think that helmets are some kind of magical protection charm.
Posted : 27/07/2010 10:45 am
Thanks to IanMunro's pic my helmet is now leaking.
 LHS
After the helmet crack the helmet does not provide any more energy dissipation to the wearer. During the compression of the EPS liner the acceleration seen at the head decreases dramatically and during the fracture mechanism the energy is dissipated even further.
On an acceleration pulse plot you will see spikes during the initial impact, upon the bottoming out of the foam and after the energy dissipation due to fracture.
Believe me ALL of this plays a VERY constructive role in head protection.
Posted : 27/07/2010 10:49 am
Although I would always wear a helmet, they can most definitely make injuries worse in certain conditions.
I managed to lose my line whilst riding through a steep sided 'gully'. Bars glanced the soft side of the trail, causing me to spin into it. Helmet peak caught and rotated my head backwards whilst I was still traveling forwards. Still have a sore neck and headache 4 weeks on. I suspect that the design of the helmet contributed to this. A Zen fwiw. Large circumference for given head size on this helmet. Face made contact too, but was unmarked.
Wish I had been wearing my much closer fitting, and peakless, roadie helmet !
Posted : 27/07/2010 10:51 am
 LHS
Anything that presents itself as a snag hazard will always be at detriment to protection. Any helmet peak should be designed such that it will snap away with a very low force so as to avoid the incident as described.
Posted : 27/07/2010 10:53 am
For what its worth, having had a relatively high speed (c.20 mph) head to tarmac incident recently. An inspection of my helmet shows compression over much of the front right hand side, and where the helmet has fractured it follows the line of deepest compression. That helmet has not failed, I cant say what state I would be in if I had not had it on, and I don't care to dwell on it.
Posted : 27/07/2010 10:54 am
 LHS
Molgrips, can't figure out how to PM on here to discuss, in answer to your question - both.
Posted : 27/07/2010 10:55 am
There are no PMs on here, you have to email - mine is in my profile.
But cool to see someone working on scientific R&D for bike stuff - I am jealous 🙂
Posted : 27/07/2010 11:28 am
 Solo
[i]Yeah but in all fairness, you are not doing any research or experimentation, you are just guessing.[/i]
In all fairness MolGrips, you're quite wrong.
I have worked in the field of passenger restraint/occupant protection.
You may now remove your foot from your mouth. Top marks for getting it in there though.
[i]Believe me ALL of this plays a VERY constructive role in head protection.[/i]
As above, I wear one, and I beleive that in a lot of cases, a helmet is better than none at all. And while I'd never seek to rubbish the hard work developers put into the current design of the common helmet, I think we could benefit from a different approach to design.
[i]Wish I had been wearing my much closer fitting, and peakless, roadie helmet [/i]
My case in point, design, I believe, has some way to go yet, if it does at all.
S
Posted : 27/07/2010 11:30 am
For example..............................the floor is yours. What would you do different?
Posted : 27/07/2010 11:39 am
molgrips, I think he just gets wound up by the usual suspects saying things like "if I hadn't been wearing my helmet I'd be a vegetable now..." and when he tries to suggest that that might not necessarily be the case, people tend to get a bit angsty about it.
It may be 'bleedin obvious' but a lot of folk seem to miss it...
Posted : 27/07/2010 11:44 am
 Solo
TT.
Oh, thats kind of you, but thats also a pretty impracticle proposition for a forum.
Just because I think it could be done differently, that doesn't mean I don't understand where we are now. As previously posted, when considering issues of safety, comfort, cost, I can see why we are here, but will it, should it be better.
Looking at some of the pics here of broken hats, I'm grateful the wearers claim to be Ok afterwards (regardless of being STW contributors 😛 )
But I think theres room for improvement, if for no other reason that to address the Nay-sayers, but really to reduce the percieved/alledged downsides to wearing current designs.
Or are we saying that current design is as good as its ever going to get ?.
Cheers.
Solo
Posted : 27/07/2010 11:50 am
 Solo
[i]It may be 'bleedin obvious' but a lot of folk seem to miss it...
[/i]
Yeap, I agree.
S
Posted : 27/07/2010 11:52 am
If you think we could benefit from a different approach to design, but can't say why, what the differences are or what is wrong now, then what benefits do you think might be realised?
Posted : 27/07/2010 11:57 am
 Solo
[i]but can't say why[/i]
Nice try, but its not practical to go into this here.
Ta
S
Posted : 27/07/2010 12:01 pm
 LHS
Same can be said for pretty much any product, but when you take into account the list of variables in the design you will realise that modern helmet design is very good.
You need to consider:
Weight
Size
Anthropometric head range
Material types
Impact Protection - Front, rear, side, crown, oblique
Penetration Protection
Durability
Manufacturability
Retention strength
Non recurring development cost
Recurring cost
Style
Cooling
Comfort
Posted : 27/07/2010 12:03 pm
 juan
The bigger the helmet the better the protection... At least it's what most of test for crash helmet (from TJ's LR) seems to prove.
Agree on the peak. Funnily enough most of modern helmet have a peak that move/disengage under impact...
^^^ Cop out!
As for "I'd be a vegetable now" - I think that's a natural and excusable oversimplification. I don't think the layman pretends to know all about the intricacies of head trauma. However, a lot of people would almost certainly be in a lot more trouble without their helmets.
Like my mate who I had to pick up off the hardpack one summer afternoon many years ago after a bad high speed faceplant. He spent the night in hospital with concussion, and he was wearing a lid. Had he not, he'd have almost certainly had worse head injuries, and his nose would definitely have ended up all over his face.
Posted : 27/07/2010 12:08 pm
 Solo
LHS.
You repeat a point I've already made. I would add though, that a cycle helmet isn't just any other product.
[i]Agree on the peak. Funnily enough most of modern helmet have a peak that move/disengage under impact...
[/i]
Things move-on.
S
Posted : 27/07/2010 12:10 pm
LHS - there is some debate about the density of the polystyrene with some experts believing that the densities are too high leading to good performance in the testing but poor performance in the real world. There is data out there on this
nickc - ta - that is pretty much my point along with :-
I want to see a lot more and better quality research, better design, much more stringent testing including oblique impacts to test for rotational effects. Some testing has shown up to 1/3 of all oblique impacts injury severity worsened by the rotational accelerations.
As for my own usage - I just bought a Giro Xen as it fitted me well and has no sticky out bits. I also have a piss pot style helmet for winter / jumping type usage as I believe it offers marginally more protection but is too hot to wear all day - but if all I am doing is pootling around I don't wear one
Posted : 27/07/2010 12:11 pm
 Solo
Ah !, Molgrips, I wondered where you had got to.....
S
Posted : 27/07/2010 12:13 pm
 LHS
LHS.
I don't think I did. You assumed that it was easy to improve on helmet design but then provided a complete inability to explain as to how.
 LHS
Yes, a lot of the data out there comes from the work we do.
Posted : 27/07/2010 12:14 pm
 Solo
[i]better design, much more stringent testing [/i]
Yeah, I'd like to see that too. But of course, there'll be a cost.
This is the dilema, the compromise.
S
Posted : 27/07/2010 12:17 pm
 Solo
[i]I don't think I did. You assumed that it was easy to improve on helmet design but then provided a complete inability to explain as to how[/i]
v v v
[i]Solo - Member
Hhmmm. Helmets...
The cracking of the helmet indicates energy dissapation, energy that would have otherwise had to of been dealt with, by natures protection...
However, upto the point the helmet failed, most of the energy was being passed to the head, imo.
My experience leads me to think that current popular helmet deisgn does not absorb much energy. The polystyrene, as dense as it is, seems to transmit energy to my head quite well.
I was reminded of this recently when for the first time in a long time, my helmet clipped a low branch.
It was still quite an abrupt shock to my head, very little energy had been absorbed by the helmet, there wasn't much cushioning of the blow and I attribute this to the dense polystyrene and the absence of a more compliant, cushioning, layer of material.
However, the skin had not contacted the branch so I wasn't left with any cuts, etc.
Current helmet design seems to be a compromise to meet several criteria, not all of which may be safety/crash centric.
[b]How many helmet group-tests have we read where the journos refer to "cooling", "airflow", and even asthetic featrues ?
Throw into the mix, manuf costs and its not difficult to see how current helmet design has arrived at where it is now.[/b]
I don't think current designs are the best mankind could come up with for the primary purpose of preventing significant head/brain injury.
I think we only need look at helmets from other sports to get an idea of the solution other companies have come up with to try to prevent serious head injury.
Personally I fail to see the difference between a motorcyclist hitting their head against a lamp post at 25mph, and a mountain biker hitting their head against a tree at 25mph.
Yet, the helmet design solutions for each are very different...
But then again, who's going to wear a motorcycle helmet for a quick bit of XC riding ?.....
I'm glad the OP is Ok, and if they think that their helmet prevented a more serious injury, then thats fine.
However, I tend to think that it shouldn't be a question of whether or not to wear a helmet, there is definately a need for head protection.
But rather, which design solution should we be wearing ?.
Cheers.
Solo
[/i]
I have provided no such inability. When did I write that it would be easy to imporve the design ?.
Look LHS, don't get wound up. You should knwo full-well its not practical to [i]design[/i] a helmet in a forum posting and to invite someone to do so either implies that such work can be done this way, or other.
Are you telling us that [i]your[/i] work has led us to the ultimate helmet design and improvement is no longer possible ?.
S
Posted : 27/07/2010 12:28 pm
Other improvements I would like to see are better fit and retention systems - the "one size fits all" with the band is experimentally shown to reduce efficiency greatly.
I would also like to see further coverage - helmets that come down below the ears, onto the back of the head and onto the cheekbones - like some sking helmets
I like the developments in sliding layers on the outside to reduce rotations as well.
As solo says - its rather hard to see why differing sports with similar requirements end up with such different designs of helmets - unfortunately fashion and consumer acceptance plays a large part.
LHS - can you tell us who you work for?
something more like this is shape - but with more ventilation and made in EPS with a low friction outer layer - but not a hard shell.
Posted : 27/07/2010 12:39 pm
 Solo
TJ.
You're a brave soul making such specific suggestions, I had avoided it so as not to turn this into a flaming session.
Like you, I just think there could be more, and I hope there will be, for all us cyclists.
S
Posted : 27/07/2010 12:46 pm
 LHS
TJ, I curently work in the design, development and testing of Fast-Jet and Helicopter Helmets.
Posted : 27/07/2010 12:53 pm
Not read all of this thread and i like most here would choose to wear a helmet and have thanked my lucky stars on a few occasions that i had one on,,,,however i read in a mag or on tinternet a couple of years back a debate about the merrits of a helmet in certain crashes, the incident in question was where a guy crashed and did a forward roll, and subsiquently brock his neck and was paralized as a result. the theory was it was the shape and size of the helmet that put extra force on his neck causing the damage!! Like I say I always wear one if only for the extra mental confidence it gives me but these stories of helmets causing injury also exist.
I don't know about anyone else, but my own lid has bashed, clonked and scraped and been generally abused by countless overhanging branches and twigs and such like, especially in the summer months, to know without a doubt I'd have grooves in my scalp that would not look at all pleasant.
Plus I've thrown my head down several XC trails and a bit of Watford High Street over these past 4 yrs in order to test my own feelings that I would not leave home without it. Nor can you compete in any XC or downhill race that I know of without one.
I've also raced m'bikes at club level and have slung it down the tarmac four times = 4 new helmets = £!
Posted : 27/07/2010 1:05 pm
Unfortunately donks you don't know what kind of crash you are going to have before you have it.
I do wonder though about the bit that sticks out of the back of many bike helmets. Could this be causing problems? It's notably absent from a Xen.
 Solo
[i]I do wonder though[/i]
Yeah, me too...I wonder how one can accuse a person of "guessing" and then get it so completely wrong.
S
Posted : 27/07/2010 1:10 pm
molgrips - it could be - we really don't know. Certainly the added leverage of sticky out bits theoretically could increase rotational forces and injuries - which may be a particular type of injury known as a diffuse axon injury. It also is increases the size of your head thus making it easier to hit. It could also catch on obstructions thus giving rotational accelerations.
NO real good data on it that I know of - rotational accelerations being made worse by helmets is proven experimentally but what part shell shape has to play in this is not known as far as I know
Posted : 27/07/2010 1:17 pm
One of the dangers with helmets - risk compensation. Feel more confident and take more risks
Posted : 27/07/2010 1:18 pm
Solo - your last on my comment confused me - I've got no idea what you're on about. LHS knows his onions and understands compromises and user requirements and performance balanced against the art of the possible - be that human or financial limitations.
If people want the levels of protection linked to motorized sports, they are free to purchase and wear. If they want something that passes an international standard and gives a reasonable level of protection, they wear a bike helmet. Don't blame the manufacturers and don't blame the magazines for not testing to destruction. Don't pontificate that it could be better then offer no alternative - thats where people find you have no substance. Do your own risk assessment for your own life and take responsibility for your own purchases, actions and headwear.
Posted : 27/07/2010 1:21 pm
And have more fun
Posted : 27/07/2010 1:23 pm
Safety Tips
1) Do not Crash
2) If you must crash do not bounce on your head
3) If you must bounce on your head avoid hard and pointy objects
4) If you can't avoid hard and pointy objects protect your head
5) If you protect head avoid accidents where rotation might be a feature.
6) If you can't avoid accidents where rotation is a feature you're ****ed.
Besdies that there are two major flaws in TJ's argument.
a) The implication that it is possible to choose how and when you crash.
b) That we, the great unwashed, presume that helmet will save our sad lives in every circumstance rather than just mitigate some of them.
The research that is so frequently quoted is fundamentally flawed, in that all of those occasions when a helmet had been worn and there has been no bad outcome are ignored. It follows for example that there will be little or no investigation of the incident with the OP because the outcome is not severe enough to warrant it. Whereas a serious injury or death will. Therefore it is relatively easy to arrive at the conclusion that having a fall when wearing a helmet often results in death or serious injury. Whereas the fact is that all of the incidents where that has not been the case and in fact the helmet has prevented that outcome by that very token go unreported and uninvestigated.
Posted : 27/07/2010 1:39 pm
At first glance it thought this was titled "weigh your helmet kids"
Posted : 27/07/2010 1:40 pm
[i]"Helicopter Helmets." [/i]
They sound ace, whats their range like and how much weight can they carry? 😉
Posted : 27/07/2010 1:46 pm
 juan
No, I don't think so. Nothing stop you to wear a motorcycle crash helmet TJ. It will offer you much more protection. So why don't you wear one?
Cycling is a very specific sport. Different from running, skiing, Mxing, ****ing-horse riding and so and so. Therefore helmets have a different design to all the other sport. Where I don't agree with TJ is when he says that there is some data about rotational injuries. You have fail to provide with a peer review study of clinical cases about rotational injuries resulting of the presence of an helmet. Another point is that most of the studies are fairly old and still crash test some even older (cheaper) helmet design. The fact that we even have different helmet for on road and off road means at least one thing. Helmet manufacturers start to see that both sport are different and therefore the conundrum is that helmet design should be different.
Posted : 27/07/2010 1:53 pm
Motor sport generally doesn't require pedaling, so the heat generated is much less. Even on a cool day a cycling helmet can get very hot, so it seems impracticable to me that 'piss-pot' or ice hockey style helmets could be used on a bike without compromising the experience from a comfort and safety perspective. Cooking your head in an enclosed design is going to be dangerously distracting. It's similarly clear to me that many road helmets successfully take this compromise into consideration.
Posted : 27/07/2010 1:54 pm
 hora
The accidents I've had with my helmet on happened in a blink of an eye with zero warning.
 Solo
[i]your last on my comment confused me - I've got no idea what you're on about[/i]
You are, of course, at liberty to go read the thread, but that is perhaps more difficult than trying to flame someone...Ok.
I've voiced a belief that cycle helmet design could be better from a primary performance perspective.
I have worked on passenger restraint and protection systems.
You and LHS have reacted as if I know nothing about Engineering and crash testing, etc. A poor assumption.
I have not blamed anyone for anything, merely pointed out how I see where we are right now with current helmet design, etc, etc, for reasons of cost, comfort, manuf, blah, blah.
You seem to have consistently missed this, in order to just try to have a go.
[i]LHS knows his onions and understands compromises and user requirements and performance balanced against the art of the possible - be that human or financial limitations[/i]
And the rest of us know nothing ?...
[i]Don't pontificate that it could be better then offer no alternative[/i]
I laugh at your trying to get me to design a helmet here, on a thread.
TJ has offered up some good suggestions for starting points.
If anyone is pontificating, its you.
Are you really saying that current cycle helmet design can't be improved upon ?. REALLY ????
[i]Do your own risk assessment for your own life and take responsibility for your own purchases, actions and headwear.[/i]
Errr...Yeah, thanks for that, but I think most of us already do 😆
S
Posted : 27/07/2010 1:55 pm
 Solo
[i]The fact that we even have different helmet for on road and off road means at least one thing. Helmet manufacturers start to see that both sport are different and therefore the conundrum is that helmet design should be different.[/i]
And its nothing to do with selling me a helmet for the road, and another one for off-road...
Just what are the [i]real, effective[/i] differences between MTB and Road helmets, in relation to them performing their ultimate function, in their current form ?.
Posted : 27/07/2010 2:15 pm
 GW
I crash a hell of a lot and it usually is possible to choose how and when I crash, it's the few times it's impossible to choose or I make a bad decision in the split second before/during the crash that I've actually been hurt worst. Knowing how/when to crash/bail is often more important than wearing a helmet IMO.
Posted : 27/07/2010 2:30 pm
The rotational forces seem to have caused this thread to go round in circles!
Posted : 27/07/2010 2:36 pm
 LHS
Just what are the real, effective differences between MTB and Road helmets, in relation to them performing their ultimate function, in their current form ?.
Would you wear a full face helmet when out on a road ride?
Posted : 27/07/2010 2:42 pm
Everyone, TJ always backs down when you offer him a calibrated whack on the head with or without a helmet. Keep the odds on your side if you want to stay safER, wear a helmet. TJ is right, there are no guarantees of absolute safety.
 Solo
[i]Would you wear a full face helmet when out on a road ride?
[/i]
Should have gone to spec-savers
[i]Just what are the real, effective differences between MTB and Road helmets, [b]in relation to them performing their ultimate function[/b], in their current form ?.
[/i]
S
Posted : 27/07/2010 2:50 pm
Giro Xen
Giro Atmos
Atmos (the road one) has more vents, a sticky out bit at the back, it's smaller, thinner, doesn't go down the bac as far and has no peak.
Posted : 27/07/2010 2:55 pm
 LHS
You need to elaborate on what you are getting at. Its unclear.
Posted : 27/07/2010 3:02 pm
here's an interesting paper - it says that a lot of the talk about "not making a difference" comes from poor statistical analysis - the conclusion is interesting.
Misconceptions regarding case-control studies of bicycle helmetsnext term and head injury
Accident Analysis & Prevention
Volume 38, Issue 4, July 2006, Pages 636-643
we should probably all be wearing a slightly more beefed up version of the met parachute (with the detachable chin guard...years ago I raced bmx - we all used to wear pretty much full on motorcycle lids then...
Posted : 27/07/2010 3:08 pm
more literature...TJ - do you ahve access to science direct - i.e. can you search for these?
"Current previous termhelmetnext term designs provide adequate protection for typical oblique impacts onto a road surface, in terms of the peak linear and rotational head accelerations. Most criticisms of current previous termbicycle helmetnext term designs are not valid: although test headforms lack a deformable scalp, and so have a high contact stiffness, this does not lead to inappropriate designs; there is a linear increase in the peak impact force with impact velocity, not a just sub-lethal level for minor impacts."
International Journal of Impact Engineering
Volume 35, Issue 9, September 2008, Pages 1075-1086
Posted : 27/07/2010 3:10 pm
What is the purpose of a peak on a MTB helmet?
I know it makes you look more RAD but it cant be that.............can it??
Ive been using a skateboard helmet due to lack of cash but I do suffer from boiled head syndrome. It got too much last week so there's a [i]proper[/i] MTB helmet on its way in the post
Posted : 27/07/2010 3:13 pm
Looks like this has just descended into the usual bitch-fest I've noticed is common on here.
FWIW; I had a crash last year, broke my helmet, would probably have ended up with quite serious injuries if I'd not been wearing it. Helmet absorbed the impact and did it's job. I'm not expecting it to perform miracles, but if it makes just a 10% difference between the chances of sustaining serious injuries or not, then it's worth wearing one, in my book. Tandem Jeremy has come out with some pretty weird stuff on this, I must say.
i'll just listen to the 'evidence' that my helmet probably saved my from serious injury. That's good enough for me.
Specialized replaced it (it was 5 years old) without me having ay receipt for it, with a heavily discounted one. didn't even ask for postage. All within a couple of days of me sending the old one to them, and they returned the broken one so that it could be used for a kid's cycling safety scheme to demonstrate the effectiveness of wearing helmets (they had fun bashing it with a hammer!).
Helmets FTW.
Posted : 27/07/2010 3:18 pm
 GW
That makes perfect sense.. hitting jumps flat out bangin bars with 7 other riders, in that situation wearing a neck brace makes a lot of sense too. neither make a lot of sense for pissing about round wooded singletrack though.
I can't be bothered to read all the posts on here, the first two pages were enough but i just can not believe that people are still debating that helmets are not a good idea. I totally agree that the fit and sizing of the helmet is criticle, and I get wound up by people cycling past with the helmet resting on the top of their neck but i know from personal experience that [i]correctly fitted[/i] hemets SAVE LIVES. I have had two or three massive crashes (not bad in nearly 20 years mountain biking :wink:) that have smashed/cracked helmets that without would have killed me. Thats not me being melodramatic. I'm all for looking at the facts of things and reasoned debate but to say that wearing a helmet is not going to reduce your chance of serious injury from head trauma is bordering on the ridiclous 🙄
Posted : 27/07/2010 3:22 pm
Keeps the sun and rain off your face. I wish my road helmet had one, sometimes I use the MTB lid in wet weather because the peak really helps.
Posted : 27/07/2010 3:33 pm
Juan - there is specific good data on rotational forces - I have posted the references several times. Some of them are on this page - there is loads more evidence of this and some companies are now attempting to make helmets to mitigate this
http://www.cyclehelmets.org/1182.html
It does amuse me how what I say gets distorted.
All I have said here is :
A helmet that has split has failed and has not made significant difference to the severity of any injury.
Helmets provide little protection against major injuries even when they have worked properly
There are drawbacks to helmet design and they could be improved.
Posted : 27/07/2010 4:59 pm
Disagree. It could have deformed (not visibly) taking up lots of energy, and flexed, THEN split. Lots of energy absorbed and not transferred to your bonce.
Again disagree. If it absorbs 10% of the energy of a big smash, then that's 10% less for your brain to deal with.
Not disputing that.
Posted : 27/07/2010 5:08 pm
So let's say that Simwit landed on the stones without the helmet. The effect would have been similair to being struck with a ball pein hammer. That sort of impact would have certainly caused significant trauma to the tissue around the impact point. There would also be a chance of a fracture to the skull (no matter how small), or, in the worse case, an indentation in the bone.
What part of that [i]isn't[/i] serious?
Posted : 27/07/2010 5:23 pm
I don't care what anyone says, concrete is hard. If my helmet scrapes along it instead of my head, I will probably be OK. If my head scrapes along it instead of my helmet,I will probably not be OK. So, I wear a helmet. The same as I wear a seatbelt. It doesn't prevent an accident, but it does improve the chances of walking away from most types of one.
But there are types of accident where a helmet or seatbelt could make me worse off, but I believe them to be less frequent, so I will still wear a helmet.
I don't care if no one else wears one (apart from my kids), as long as they don't expect me to pick them up afterwards.
Posted : 27/07/2010 6:07 pm
That cycle helmet site is wierd.
It seems to state that by forcing the use of helmets it increases the risk of serious disease due to obesity as a result of people not cycling.
So what about education? Go cycling and wear a helmet = Best of both worlds?
Posted : 27/07/2010 6:20 pm
 LHS
Could not be more wrong, the fracture process is a designed in feature of helmets to aid with the spread and dissipation of energy.
That doesn't even warrant a reply, I have no idea why you think this but its mind boggling.
There is always room for improvement, and it will depend on what YOU would decide is the most important aspect. Don't be fooled into thinking it is as easy as just making a helmet which has double the thickness of EPS liner around the entire circumference of your head though.
Posted : 27/07/2010 6:33 pm
LHS - 'cos that is the evidence states. Real peer reviewed studies. Cycle helemts are only designed for low speed low energy impacts - whith high energy impact they do very little.
I know a thicker eps is not the answer - its the behaviour in oblique impacts I am particularly concerned with and fit andf retention. Bigger increase the chance of hitting your head and increases leverage
Posted : 27/07/2010 6:37 pm
Solo - I'm trying to extract more than a criticism or a question from you. Most all of your posts on this topic have questioned current design or thrown out questions to other posters. I have always been taught that criticism without a proposed alternative is nonconstructive and your posts have shown none of your suggested improvements over what we have. Nothing more.
Posted : 27/07/2010 6:41 pm
LHS - some discussion of the failure of helmets to protect against serious injuries
http://www.cyclehelmets.org/1054.html
Anecdote not evidence
Posted : 27/07/2010 6:49 pm
Page 2 / 5
