wanting to try 1x o...
wanting to try 1x on the gravel bike but a couple of questions around chainrings
Im looking to try out 1x on the gravel bike, i have a clutched 810 grx rear mech that will take at least a 11-40 cassette does anyone know if it will manage an 11-42?
also a cheap try out options as i have a clutch mech, and a spare 105 chainset, i was looking at trying a 39t 105 inner ring (£12) but on the other ring placement, I assume i'll need some new chainring bolts as well. apart from it not being narrow wide is there any other major downfall to this idea?
thanks
Posted : 14/02/2025 10:25 am
Fit a good chain guide with a 39 or you'll get a lot of dropped chains when in the smaller cogs at the back. A narrow wide would be better. And yep you'll need new bolts, I think I used these before.
Sure the mech will work fine with a 42 and enough chain.
Posted : 14/02/2025 10:50 am
Most of the chain retention in a 1x setup is in the narrow-wide ring, not the clutch mech, so as above, you'll need a chain guide of some sort - you could just lock/jam the front mech in the right place if you're currently running 2x
Posted : 14/02/2025 11:16 am
Narrow wide rings can be had for relatively cheap, I'm not sure what BCD your crank is but I can see them for 105 type cranks for £15ish. I wouldn't bother trying a 1x setup without a NW ring or singlespeed specific ring, chain will fall off lots.
Posted : 14/02/2025 11:21 am
narrow wide for around £15 - where please that would be helpful
Posted : 14/02/2025 11:30 am
super cheap narrow wide "snail" brand on amazon or ebay, have used them on MTB's before and they are fine, especially for testing
Posted : 14/02/2025 11:34 am
812 RD works with 51t cassette
Posted : 14/02/2025 12:20 pm
yeah, but the 810 is the 2x rear mech, which only goes up so far. Given how conservative Shimano are, I'm sure it'd take 11-42 though.
Posted : 14/02/2025 12:23 pm
I'd leave the ring on the inner position of the crank, you'll get a better chainline to the larger sprockets where you have less derailleur arm articulation to accommodate the chain angle.
Posted : 14/02/2025 1:10 pm
I'd agree with the snail brand rings - surprisingly good. New bolts are nice, but a washer on each one, between the bolt and the crank, takes up the space of the other ring.
Posted : 15/02/2025 2:01 pm
@infovore I always thought rear mech capacity was the total (front plus rear) so if you’re running 1x you can get by with a shorter cage than you might otherwise need for the same cassette? So, a mech that’ll manage 11-40 with a double should be fine for 11-42.
Might have misunderstood though…
Posted : 15/02/2025 5:30 pm
There's the issue with the B screw gap between the top jockey wheel and the large sprocket as well, but yeah, I reckon only running 1x up front would gain you a couple of teeth capacity.
Posted : 15/02/2025 5:53 pm
