Wall Ride - Design ...
[Closed] Wall Ride - Design Geometry Help Needed
[#7449065]
[b]1. You have a "straight" fallen tree running horizontally 2.5m high and want to build a curved wall-ride against it.[/b]
Working out from the centre, (to enable the rider to "stick" as the incline increases), will the footing trench (for the 30 x 6"uprights) need to be dug as
a. a diagonal trench 45deg (each side)out from centre
b. a semi-circle starting from the footing of the steepest upright
c. Some kind of ellipse
d. Some thing else
Posted : 11/11/2015 12:42 pm
the run in and overall length and run out is all important here. if you approach say 30-40degrees from parallel at speed you will probably be able to carve the whole length without any curve. you will want a transition on and then go nuts. the angle of the run out will also effect what you build. if you want a 180 berm thats more tricky.
with enough speed and a decent angle of approach you can stay on a wall quite a long time.
are you planning to jump off the end or rolling off? i've never built one that you roll off but i've ridden a few and they get boring quickly. i`ve built a few wallrides. one you jumped onto. there was never any science involved when you scope it out you will be able to tell.
oh and you *will* need chicken wire to ride it unless its properly dry as the wood gets super slippy quickly especially with a few muddy tyre tracks.
after a while you will be building a kicker on to it for even more fun.
Posted : 11/11/2015 2:55 pm
Looking to roll in - jump off, but your reply has get me thinking a jump in will be loads more fun
Hoping to scour the logs enough with a chainsaw to avoid chicken wire. Not much mud around so may work okay
Posted : 11/11/2015 5:30 pm
Posted : 11/11/2015 5:41 pm
logs/chainsaw/no mud! where is this being built?
its been a while since it was burnt down but i recon our one was about 7-9m long and a good 2m high and you could jump off the top at the end. it had a slight curve but i dont remember it being bonkers. we made it so you could gently hop off (second wallride build but first this size) but quickly realised that when you hit it fast a little hop off wasnt an option. go fast, hold-on and fire yourself out the end at mach 10.
we then did a gap-on elevated wall ride that was shorter but still fun. that is dead straight and you do need to kind-of hop off a bit rather than ride off. its also not 100vert at the landing on but does get more vert as you go. I wanted it to curve back a platform drop at teh end but time, materials, motivation and the rest of teh tree got in the way!
i loved building stuff like this. see saws - skinnies - tree rides. we dont have huge elevation or steepness so we needed to make it happen
Posted : 11/11/2015 5:58 pm
Posted : 09/07/2016 10:36 pm
This video is private
Posted : 09/07/2016 11:13 pm
Whoops fixed
Posted : 12/07/2016 3:31 pm
 colp
The big 2 on the Leogang FR/DH track work really well, you can hit them at maybe 35 mph.
Here's the second one from the end
Posted : 12/07/2016 3:39 pm
That's a wooden berm, not a wallride 🙂
Posted : 12/07/2016 3:41 pm
