Anyone done this? Experiences?
Ive just changed mine from yellow to orange as i found i was using all the travel pretty much all the time (but yet not bottoming out ???). Now with the larger orange spacer added and running 30% sag (as before) the o-ring is stopping about 5mm from the end of the shaft even when i hit the 4' drop in my back garden.
Not sure which i prefer. Thoughts?
I weigh about 90kg if that helps.
Posted : 11/07/2019 3:26 pm
Sounds perfect.
Posted : 11/07/2019 3:58 pm
Thanks. Yeah it probably is. Ive just let all the air out and the o-ring is finishing at exactly the same spot as a fully compressed shock. Just might need a bit of getting used to in terms of feel as it has certainly stiffened up the back end on the drops and stairs in my back garden (my testing loop)
Posted : 11/07/2019 4:17 pm
