Valve core for tube...
[Closed] Valve core for tubeless tyres (possible bimbo content)
I'm using the Stan's No Tubes system and every time I put air in a tyre, the valve core launches itself like a rocket and disappears into thin air.
So my question is should I use pliers to tighten it sufficiently, bearing in mind that I would need to carry them on the trail. Or is there something else I could do?
On the No Tubes website it says that no other valves should be used, is this true?
Thank you so much!
Posted : 29/10/2009 7:33 pm
You can get a valve core remover tool. http://www.freeborn.co.uk/shop/components/tubeless-conversion-kits/702-stans-notubes-valve-core-remover
But once you've tightened it up once with the pliers it shouldn't come out when you put air in.
Posted : 29/10/2009 7:38 pm
You can get a little widget that allows you to tighten them up but is small enough that you can't bu&&er the threads. Pliers sounds a bit drastic. I have a very tiny spanner that I use, looks like it came in a kinder egg.
[url= http://www.justridingalong.com/shop.php?product=48 ]core extractor[/url]
Although if the core shoots out it sounds like you haven't engaged the threads fully.
Posted : 29/10/2009 7:42 pm
Go to your LBS, should be able to get one of those valve caps that doubles as a core tool. Mine cost 50p!!
something like this:
Plus you will always have it with you when on the bike!!!
you can use any old presta valve cut from an old tube and use pliers to tighten it. just carry something you can undo it with in the unlikely event you need to put a tube in. I just unseat part of the tyre if i need to top up sealant.
Posted : 29/10/2009 7:44 pm
I use a spare chain link to tighten/undo Stan's valves - the narrower bit fits just right.
I'm probably being dumb, but why would you want to take out the valve on the trail?
Posted : 29/10/2009 8:18 pm
That assumes we're talking about the Stan's style valve body with the flats on it - and not the actual core....
Posted : 29/10/2009 8:20 pm
CG I've got some spares of those that Conor showed a pic of .I'll bring one Sunday if you want .BTW Did you get my last e mail ?
Posted : 29/10/2009 8:34 pm
Thank you for your replies. It seems to be that when I remove the black plastic dust cap, it somehow unscrews the valve where you add air and thus unscrewing the core valve. Sounds absolutely silly I know!
Does anyone else have this problem?
Of course I'm such a bimbo that there should be no need to take pliers out with me on the trail.
I'm confused ๐Ÿ˜ณ
Posted : 29/10/2009 8:38 pm
Sounds like the core just isn't tight enough to start with - if you tighten it up with plyers it shouldn't come out when you unscrew the dust cap. I've stopped bothering with the dust caps now though personally.
Posted : 29/10/2009 8:42 pm
CG if you use one of the aforementioned they tighten the valve core up thus stopping it coming undone accidently.I use to get metal ones when i bought Slime now they are plastic.
Posted : 29/10/2009 8:48 pm
the pic above is for a schraeder valve isn't it? - CG's is presta, I imagine
you need to tighten it in fairly well, good thumb-tight (with pliers if necessary but don't go mad). Suppose it's possible you (or someone else?) have stripped the thread when using pliers in the past. If not, could always use WEAK threadlock on it if won't stay put.
Posted : 29/10/2009 8:59 pm
You shouldn't be able to unscrew it with your fingers, so do it up a bit tighter than that with pliers or OF's tool and all should be well ๐Ÿ™‚
Posted : 29/10/2009 9:05 pm
Yes, it's presta. The core valve seemed to need tightening at the rim end and a little bit of sealant dribbled out.
This has happened with a few of my wheels now so reckon that pliers are the way to go otherwise this will keep happening.
Thanks again for your help everyone ๐Ÿ™‚
Posted : 29/10/2009 11:56 pm
They look a lot more fiddly than the old ones from JRA with a little plastic A shaped core remover that weighs hardly anything. New Mavic ones from JRA come with little plastic A. Got 3 sets of them and never had a problem and little plastic means you tighten up but not too much.
Best to ring Jon at JRA for advice on which valves are right and see if you can change as looks like a new valve needed anyways
Posted : 30/10/2009 12:33 am
 mboy
C_G I have JUST the tool for you...
Remind me on Sunday (I'll bring it along) and I'll give it to you as I don't need it any more... You'll be amazed at how simple, yet effective it is, but it means you won't have to carry pliers around also!
Posted : 30/10/2009 12:56 am
Thank you mboy!
Posted : 30/10/2009 1:00 am
