Using boost adapted...
[Closed] Using boost adapted front wheel in non boost fork?
 FOG
I have bikes with both boost and non boost forks. One front wheel has boost adaptors but I want to use it in the non boost fork. Obviously leave out the 5mm spacers but is there enough play in the caliper mounting slots to compensate for the disc spacer?
It would be a bit of a faff to remove it every time I changed wheel.
Posted : 11/02/2022 9:54 pm
Pretty sure it’s a faff. Surely you’d be best buying a non front wheel instead of swapping it between bikes.
If both forks were boost or non boost it would be much less of a faff.
Posted : 11/02/2022 10:00 pm
