Using a standard fo...
[Closed] Using a standard fork on a G2 geometry bike
 nbt
So, the G2 geometry fox fork on my Gary Fisher Roscoe is in need of some looking at - the inevitable stanchion wear has finally appeared, although given that I've done precisely ZERO maintenance of the fork since the day I bought it (25 August 09, so just a few days short of four years ago!), it's had a good run.
The two main options are to get the fork serviced and have a new CSU fitted, or to get new forks. I reckon the cost will be about even either way, but there's no guarantee that new forks will have the G2 geometry - or at least that new forks at the price I'm prepared to pay will have it.
From what I can see, the main difference is the fork offset - 51mm for g2 forks, and 46 for "regular" fox forks. Is that right? I understand that the shorter the offset, the slower the steering is, at least for a given head angle and fork length. Will that 5mm make a huge difference? If I go for taller forks (e.g. marzocchi tend to be taller axle-to-crown than other forks for a given travel), will I need an even bigger offset?
Or does anyone know of a good source of either cheap G2 forks, or cheap Fox CSUs?
cheers
Posted : 20/08/2013 7:32 pm
fork offset can be really quite noticeable, you are correct in that a normal offset in a G2 frame will slow the steering down, make the bike a bit more reticent to turn into corners. Having played with all sorts of offset and CSU combos (including making franken-forks) a shorter offset in a frame meant for G2 can also make the bike a wee bit more prone to tuck under on tight corners.
worth checking the fox data as well from memory i thought they were 40-44mm? dependant on model in the 26" wheel size (may well be wrong on this, been a while since i looked)
Posted : 20/08/2013 7:39 pm
 nbt
GOod point there,. this is indeed for 26" wheels. I just looked at the fox forks website and found little to no actual data on the offset - the figures above have been gleaned from various forum threads found through google
Posted : 20/08/2013 7:41 pm
One other thing to check is that Fox used have a lot of the offset in the lowers rather than all in the CSU like rockshox so you may get away with a "normal" type CSU rather than trying to track down a replacement G2 upper
Posted : 20/08/2013 7:47 pm
 nbt
oh my word, it never occurred to me that the offset might be in the crown, I had simply assumed it would be at the dropout. Bugger.
Posted : 20/08/2013 8:16 pm
I think its all done at the crown,Lowers are all the same
Posted : 20/08/2013 8:19 pm
Confirmed. The offset is purely in the crown. They are the same fork as any other from the crown down. Ive seen a few G2 offset forks for sale on various websites - id take a look at that first.
Posted : 20/08/2013 8:30 pm
Apparently G2 aftermarket forks are now available from fox and rockshox
Posted : 20/08/2013 8:38 pm
Pretty sure 26 are 38mm standard and 44mm G2, 29 are 44 standard and 51 G2, though my early 29er Rebas had 38mm offset.
Posted : 20/08/2013 8:39 pm
maybe in the new forks, in the older 29er versions it was a mix of CSU and lower. Not that I've got both versions or anything from building many variations of freak fork ๐Ÿ˜€
