Using a Shimano cra...
[Closed] Using a Shimano crank with a bb30 bottom bracket. What are my options?
6 Users
Looking to replace the fsa crank on my caad x with something from shimano so I can use my stages. As far as I am aware I have 3 options:
Use a praxis bb30 to shimano bb. The best but most expensive option
Take out the existing bb, use a a sleeve (fsa  make them), then fit a standard shimano bb. Cheaper than above option but sounds a bit of a bodge
Use an adapter, ie from wheels manufacturing. The cheapest option, doesn't require removal of existing bb30 (for which i don't have the tools), but again a bit of a bodge.
I have a praxis on another bike and its great,  but if I can save some cash i will. That said, nothing ruins a bike ride like a creaking crank, so any experience of the other 2 options would be appreciated
Ta
Posted : 03/12/2018 9:14 pm
remove the existing BB, otherwise it will creak.
race face do one,also wheels manufacturing,  as do hope. i went with hope as they did a weird shell width which i needed for my DH bike.
Posted : 03/12/2018 9:19 pm
Take it out and stick in the fsa shim , usually comes with glue, converted to an English thread 68/73mm
http://www.wiggle.co.uk/fsa-bb30-conversion-kit/?lang=en&curr=GBP&dest=1&sku=5360430832&kpid=5360430832&utm_source=google&utm_term=&utm_campaign=Shopping+-+All+Products&utm_medium=base&utm_content=mckv%7Csm2tZ0SxA_dt%7Cmcrid%7C295292317327%7Cmkw%7C%7Cmmt%7C%7Cmrd%7C5360430832uk%7Cmslid%7C%7C&mkwid=sm2tZ0SxA_dt&pcrid=295292317327&prd=5360430832uk&pgrid=58852352866&ptaid=pla-571356182314&gclid=EAIaIQobChMIzY3O182E3wIV1TLTCh1jDgMcEAQYASABEgL6vvD_BwE
I’ve not had a creak out of my lefty f29er since doing it, a year ago.. and the Mt800 Xt bb is £12, and doesn’t need specialist tools to fit it, that one of my local shops used to take the p1ss
I forgot what bb my spec diverge was, but it never made a noise in 15 months, unfortunately the adaptors had seized solid, had to be cut out, went with the same type adaptor and now use a regular 68/73..
i will now avoid pf30 etc
Posted : 03/12/2018 9:26 pm
Check your BB spec - some Cannondales have an internal rib that prevents the installation of certain adaptors - like having already dumped that BB30 crock-o-shite on the world, they then make it very difficult not to use something else.
Posted : 03/12/2018 9:55 pm
Thanks dovebiker. I assume you need to remove the existing bb30 to know that right?
Posted : 03/12/2018 10:02 pm
Think that would be classed as BB30a
My Slate has BB30a and there is some internal routing through the bottom bracket for the rear disk. I believe that prevents you putting through a sleeve adaptor as there isn't enough room.
Posted : 03/12/2018 10:06 pm
No cables are routed through my bb30. Just checked.
Posted : 03/12/2018 10:09 pm
I use a Hope PF46 (there is a PF41 as well, which one you need depends on your exact bb shell type). For some reason I think Cannondale is the PF41 version but you would need to check.
It needs a special tool to fit but it's a very well made bit of kit.
I've had to do a bearing change (note to self, putting bike away for 3 months filthy and wet is really bloody stupid) but that was dead easy using a high precision drifting tool (screwdriver) and the fitting tool to press new ones in.
Posted : 03/12/2018 10:41 pm
