Using a CX bike as ...
[Closed] Using a CX bike as a road bike - good idea or not?
 Aus
So I'm not a roadie but do enjoy the occasional ride.  When I ride, it's not super fast or long but I do like the light feel and acceleration of my road bike (an old ti Airborne). I'm fairly light (67kg) and like light bikes.
But, I ride on Kent country lanes which have a pretty mediocre surface so I find my bike skittish and feel the bumps.  So 3 qns;
1) Would a CX bike (I like the look of a Ritchey Swiss Cross or Pickenflick) be much harder work / slower?
2) Would a CX bike be much more comfortable both in seating position (I have a lower spine problem so more upright?) and comfort Vs bumps/rough surfaces?
3) Some CX bikes are 1x11 which appeal for simplicity but my current 34 x 28T combo is useful on some local hills (eg Yorks Hill) ... happy to lose at the other end though?
Thanks
Posted : 16/05/2018 11:53 am
Get  a gravel bike 🙂
Posted : 16/05/2018 11:55 am
I use my Whyte Glencoe for road duties, I have come from using a Specialized Allez.
It is marginally slower to accelerate but it makes up for this as soon as they is a rough patch in the road or a kerb or drain to ride over.
I have completed a 40 mile ride on it but nothing particularly impressive.
The 1 x 11 does leave a little to be desired between cogs but for actual hill climbing it is fine as the big cog at the back takes up the slack missing with the smaller front cogs.
Summary, if you are a casual road rider then yes a CX or Gravel bike would be a good idea.
Posted : 16/05/2018 11:59 am
As DezB alludes - define CX. In the past when that was the catch-all for a road bike that could be taken offroad, then yes, i'd say get one. But a proper CX bike by a proper definition will be racy, no eyelets for guards, no bottle mounts, etc. and will not be the tool it sounds like you need.
The tool you need sounds like a gravel bike; and I rode one (not even a very good one) for two years on club runs and never felt particularly impeded by a bit of extra weight and a slightly more upright geo.
Re 1 x 11 - makes sense again on a proper cross bike designed for cross racing around a muddy field in the sleet in January, but for a go everywhere do everything bike, not many people ever wish they had less gear ratios. You don't have to use them if you don't need to, but if you don't bring them you'll not have the option.
Posted : 16/05/2018 12:01 pm
You want a gravel bike I suspect. CX bikes are (should be...) steep angled, have a high BB and are very stiff. A gravel bike, or even an endurance road bike, will have a bit more comfort, room for big tyres and would generally for the bill. Also, I'm, not sure on 1x on the road but then I'm a Luddite who can doesn't really buy into it on MTB's so am likely not the best person to listen to on that subject.
Posted : 16/05/2018 12:03 pm
IMO you'd be mad to buy a "proper" road bike rather than gravel/adventure (as above, CX these days I would take to mean a proper CX race bike which you probably don't want either) unless you are a hard-core roadie.
Not only can they cope better with crappy road surfaces, they are more versatile in that you have the option of evading traffic & going off road. I also live in Kent & whilst the road riding is pretty good, a gravel bike opens up so many more awesome options! Proper road bike is permanently affixed to the turbo these days, can't remember when I last actually took it out on the road!
Posted : 16/05/2018 12:04 pm
CX = CX bike within the rules of CX, gravel/rugged road bikes etc are more versatile and less optimised/compromised towards doing CX
Have a giant defy which is slowly making it's way back from Oz and a Canyon grail here now, the grail is light for what it is, quick when it needs to be and solid when it gets rough, if it was road only I'd swap the tyres for something faster rolling and that would be about it. I was out with a mate on the bank holiday, he popped out from behind me thinking it was drag from the bike slowing me up and then reckoned we were about the same speed.
I had a Specialised Allez that died after about 10 years and replaced it with a Arkose.
Obviously the size of tyres you can add increases on a Cross bike and the disc brakes are a real benefit compared to rim brakes.
The only issue I have is the gearing can be a bit low - spinning out happens often where a road bike would not
Posted : 16/05/2018 12:07 pm
Depends what you want and need speed wise. On a 9 mile flatish section yesterday i averaged 29.8kmh, on a Parkwood on 2.35 Maxxis Aspens. TBH, i don't really care if i can do 28 or 33kmh, both are sufficiently fine...
So i'd expect on a CX bike to have 1-2kmh more than that.... 30kmh is good enough though isn''t it ? For the comfort i'd take a bigger tyred bike every time.
 JoB
to muddy the waters a little further you needn't even look at CX bikes, there are plenty of - for a better term - adventure road bikes that compared to racier road bikes have higher front ends, slightly more relaxed angles and room for fatter tyres, the Specialized Diverge being quite a good example of the breed
some of them might be described as trendy touring bikes, some of them might nudge into gravel bike territory, the whole area is a little fuzzy edged
Posted : 16/05/2018 12:19 pm
 Aus
Ah - interesting to learn the distinction between CX and gravel, but makes sense.
Out of interest, the Ritchey Swiss Cross (I suspect the clue's in the name!) appeals aesthetically and I have a Ritchey P29er which is lovely ... assuming it had 2x10 gearing, where would you put it on a scale of gravel Vs CX (or fit for my riding)?
https://www.bicycling.com/bikes-gear/a20024028/cyclocross-8/
Posted : 16/05/2018 12:22 pm
 aP
It'll probably be fine, although exactly what anyone means by a CX bike now is a bit open. I think of CX bikes as race oriented, probably with limited tyre clearances - but then I raced CX starting in the mid 90s so my viewpoint is biased. If I was going to buy a 'capable drop bar bike' I'd look more at something that had the capability to run big tyres and also 650B, with flat mount brake mounts and some useful fixing points.
I know someone who won an E1/2 road race on his CX bike, I've ridden both of mine - custom steel and full carbon fibre - on all sorts of things from CX races, 3 Peaks, road rides, club runs, off road (Surrey Hills and the Lakes), for light touring, road and CX sportives, Paris-Roubaix, etc etc
Posted : 16/05/2018 12:24 pm
 Bez
Short answer:
1. No
2. No
If you can get yourself in the right position for road riding, that's 95% of your comfort and performance sorted; the rest is fine details whatever micro-genre of curly-bar bikes you're primarily looking at. If you want more scope for maximising comfort, look for decent tyre clearance, a slender seatpost, and a good fork.
IMO.
Posted : 16/05/2018 12:26 pm
 JoB
the Ritchey Swiss Cross you reference there is definitely an old school CX bike, it even has cantilevers 😉
they're a lovely bike to ride and you'll have no trouble treating that as a fatter-tyred road bike and more than capable of tackling some off-road (although not as capable as a modern disc-braked fat-tyred gravel bike), it will be quite racey though (it's a CX race bike) which might be an issue with your need for a more upright position
Posted : 16/05/2018 12:31 pm
What Bez  said ^^  🙂
Posted : 16/05/2018 12:33 pm
I've ridden and trained for the Fred last two years on a CX bike (CAADX so a proper one). Nice ride position, great brakes, comfy tubs / tubeless. Quite heavy compared to a top end road bike. Don't think 1x11 is right for any serious roadying on mixed terrain, so changed the cross drivetrain to 2x11.
Would say the position feels fine overall, esp the upper body, but have had problems with leg muscles getting sore and inflamed. I've never owned a proper road bike, though, so have no frame of reference to say whether it would be different. Think this is just a personal thing, an artefact of a big ramp up of training mileage compared to the short MTB rides I normally do.
Posted : 16/05/2018 12:36 pm
Much, no, but slightly. I use a Kinesis pro 6 as my winter roadie. It is slightly slower and a little heavier than my 7kg race bike. But it has guards and 28mm tyres on which probably accounts for some of that. By circumstance I did a 200km audax on it and it coped well.
No, it isn't the CX bike aspect that would make it more comfortable. It is the set up. You might be able to achieve the position better on a different bike. Some CX bikes are very race orientated so aggressive. Maybe a gravel bike would be more relaxed. I notice a massive difference fitting 28-30mm tyres on a CX compared to the 23-35 on the road bike. Advantage of a CX is it can take fat tyres and guards.
3) Some CX bikes are 1×11 which appeal for simplicity but my current 34 x 28T combo is useful on some local hills (eg Yorks Hill) … happy to lose at the other end though?
One friend rides 1x. He has it set up so he can climb all the hills, he actually struggles more on the downs where we pedal off in the big ring and he spins out. Might not be a problem if you are on your own or relaxed about these things.
My race CX is disc, uldegra, full carbon. It probably only weighs 1kg more than my roadie. I imagine they'd be pretty much matched on the road. However, with all the different sub genres that are appearing you might actually find a more comfortable roadie. Have a look at endurance (canyon) , marathon (rose), adventure road, gravel type bikes as they fit somewhere between cx and road.
Posted : 16/05/2018 12:57 pm
If you're just on the road I'd have thought a Ritchey Road Logic with 28mm tyres would be fine? I've got a P29er too and thought about getting a Logic for ages, bit too pricey new for me to justify though.
I was never entirely happy with my tripster in pure road guise, always felt like it was lacking something (maybe that was me though). Now it's shod in wider knobblies and does a bit of everything it's great!
Posted : 16/05/2018 2:11 pm
My situation is a bit like yours. Terrible roads around here.
I'm running 1x and 33mm Clement PDXes on my CX bike which is my only "road" bike. The difference around my local 30km loop is a minute or so speed wise.
Lot more fun though. Like Bez said, if you've got your position right then everything will be fine.
Posted : 16/05/2018 2:21 pm
I've been using a CX bike (Pro 6 until this winter, now Bowman Foots Cray) as my 'road' bike since my last road bike got nicked five years ago. Big slicks are brilliant (and if you listed to Compass cycles, faster). It's a far more fun road bike than my Road Bike ever was.
As said above, get a frame and position that fit you. Then you can fit the gears you want- I like 1x on mine but I find excessively close ratios annoying. Not everyone is the same though. Clearance for big tyres lets you chop and change to whatever suits you.
Posted : 16/05/2018 2:34 pm
Sounds like you need a gravel bike at the roady end of the spectrum. I have a spesh diverge that fits your bill.
Posted : 16/05/2018 2:49 pm
I use my Giant Tcx as a road bike with slick tyres on the road and i don't find it significantly slower than a road bike. It is slightly heavier but the comfort from wider tyres, d fuse seat post and disk brakes makes it a far more enjoyable ride on the country lanes.
With a change of tyres and the removal of bottle holders I race it in the local cross league
If I had to choose l bike this would be it
Posted : 16/05/2018 3:00 pm
Depends on the 'CX' bike, too.  My CAAD-X has 2x bottle mounts and mudguard eyelets, which makes it more versatile than some, but still a CX bike, I don't really buy the 'CX bikes are too stiff' mantra, with the exception of the cheap alu frames people use for racing as a place to hang old road parts there's no reason they should be any less comfortable than your average road frame.
'Gravel' seems to mean whatever you want it to mean, some bikes are CX bikes with more aggressive geometry and less mud clearance designed for racking up 100's of miles on unsealed roads.  Then at the other end of the spectrum there's older long distance touring/ITT bikes like Fargo, Vagabond etc. which have more in common with 29er MTB's but with short TT's and drop bars.
I refer to my CX bike as a gravel bike whenever it's go slicks on it, which is blatantly wrong as you could race those same slick tyres on a dry CX race course.
As for being hard work and/or slower. It's 6 of one and half a dozen of the other, yes it's slightly slower, and it feels heavier, but when commuting for example it makes cycle path diversions (i.e. jumping onto the pavement or the twisty off road cycle path that runs parallel to the busy road) quicker, which means less time crawling along filtering past stationary cars.
I suspect you'd be better served as jonba said, by one of the newer road bikes designed around 28-32mm tyres with comfy frames. Or the more racey gravel bikes like Trek's Checkpoint.
All that said, the roads round here are as shocking as anywhere else, and I still survive on 23mm tyres (which measure 25 on modern-ish rims).
Posted : 16/05/2018 3:06 pm
My gravel bike feels only very marginally slower than the road bike. It also fits better as I bought it more recently so knew what I wanted. TBH, if pushed I would probably sell the road bike and just keep the gravel one.
Running 38c Schwalbe G-Ones, which are superbly fast rolling tyres on both road and dirt.
Posted : 16/05/2018 3:12 pm
Picked up a mint Whyte Friston in Jan and neither my HT nor roadie bike have had a look-in since.
The seller threw in some 50 mile old Rouler tyres as well so I’ll give them or some others I have a whirl soon.
On Ramblers with current 1x setup it’s nearly as fast as my road bike on the flat but a fair bit slower on the climbs.  Doesn’t bother me at all though.  I don’t chain gang.  I much prefer the opportunity to take in pretty much any piece of trail I want as the bike is supremely capable.  Have ridden a lot of N Downs ST on it and it’s bloody brilliant.  Sure the real steep stuff is off-limits and the fast footy/rocky stuff is hard on the arms/wrists/hands.   Those are the only negatives as everything is smile-inducing
Will probably sell my CAAD soon ( but don’t want to).
Posted : 16/05/2018 3:18 pm
What about a Ritchey Outback?
Keeping the gravel tag and more road geometry than the Swisscross.
Thanks,
Max
Posted : 16/05/2018 3:31 pm
I use a GT grade (the roadier end of the gravel bike spectrum) with 28mm road tyres as my a road bike, i've done full ironman on it and big rides(100mile 6000m climbs) in the Pyrenees on it no problem.
I actually have two one one lower spec set up a gravel bike with cross tyres and one with higher spec (ultrgra disc), light wheels, etc as a road bike as it seems to fit me perfectly its not the fastest but it comfortable for all day rides.
Posted : 16/05/2018 3:57 pm
Since the OP has mentioned the Pickenflick as an option, and in the spirit of recommending what you have ... get a Pickenflick!
Now, just to qualify my views, like the OP, I have never been a roadie ... the only drop-bar bike I've owned in recent years (before the 'flick) has been a Saracen Hack, which I've occasionally (only occasionally mind you) shod with 28c slicks and ridden a proper road ride on. So, I don't speak as an experienced road-rider.
As winter has been so sh*te and longlasting this year, I've ridden the Pickenflick as a solely road bike until a couple of weeks ago ... and really really enjoyed it. It has a more supple ride on 28c tyres than the Hack has on 35c tyres, and my road Strava segments and general average speeds are quicker than the Hack, even when that was on road tyres. Some of my segments compare favourably to 'proper' roadies I know, on 'proper' road bikes. It's a perfectly decent performer on the road, quick enough for me, although I'm sure a 8kg carbon road bike would be a little bit quicker.
The Pickenflick is meant to be a 'proper' CX bike (although was, I understand, designed principally as the ideal tool for the 3 Peaks CX race, which is somewhat different to the usual summer/winter CX series). But it's not steep-angles & race twitchy, it's very playful off road but also quite slack (HA is 70° I think on my small frame) and stable, and has tonnes of tyre clearance ... I've got 700x42c knobblies on it with room to spare. So, its probably more a 'gravel' than CX bike.
Mine is the SRAM Rival 22 version ... I'd wanted the 1x11 but that was not available at the time. Be aware that there are no rack/mudguard mounts, so as a winter road bike, it's not ideal, and as an adventure bike, you're confined to using frame/handlebar/seatpack luggage. Also, you may want to size down ... I'm normally a medium, but found the top tube length of that size way too long, so opted for a small.
Notwithstanding some of the component quality issues (rear wheel went back for replacement bearings after a few weeks, the GXP BB lasted only 1k km's), I really, really like this bike.
Posted : 16/05/2018 4:34 pm
Given that it's all about the gravel these days then looking around for CX bargains is a great idea. I did exactly what you are asking with my eBay Charge Plug. I slightly sized up to a large and fitted a slightly smaller stem than I would have otherwise with my road bike. I'm amazed at how good a road bike it is. Fitted with 30mm schwalbe s ones it was not much slower uphill and a whole lot faster downhill. Currently with 35mm marathon Supremes and it is great for our also abysmal country roads.
Posted : 16/05/2018 5:36 pm
You'll be fine.
I'm a big fat lump and I ride a 2005 Kona Jake The Snake everywhere I'm not riding my mountain bike. On the road, in the woods, along the canal. It's great.
The Ritchey would be the classy choice.
Posted : 16/05/2018 5:41 pm
I use a cannondale superx for most of my solo riding. It has 1x11 gearing 40T 11-25 for the road, or 11-36 for off road.
1. On the road - It will be a bit harder work keeping up with a fast group, but for solo rides, or for social rides its not slightest problem.
2. I ride mine on road with 28mm tyres - its lovely; I don`t feel the tyres make much difference in speed  - but they are much more comfortable. As for position on a bike; I like to be stretched out with a slammed stem for riding - so the stem etc is set up for that.
3. I have 40T chainset, with an 11-25 when its on the road. Some of the steeper climbs can be a grind - but I get up them. When I had 11x36 cassette on it would spin up anything effortlessly.
If I had to choose just 1 bike to do it all - it would be the SuperX.
Posted : 16/05/2018 5:58 pm
What the OP requires is a touring bike. HTH
i have a 1x10 cross bike that I rode on the road with a narrow block and off road with a. 12-32. If you don’t mind the gaps the latter will see you up the Kent hills. My preference for two wheel sets is for tyres more than gears. I run a 38T on the front.
I also have plenty of road bikes, including fixed. The 1x10 is fine. Choose some Schwalbe G One Speeds for gentle off road and road.
Posted : 16/05/2018 6:08 pm
Posted : 16/05/2018 6:28 pm
 kcr
I'm the same as Jonba. Most of my riding is on a bike built around a Kinesis Pro6 frame. It does daily commuting duty, winter training, touring and I've ridden 400km Audaxes on it. It's got mudguards for all year convenience and a lightweight Tubus rack to carry panniers when I need them.
Ignoring the current marketing terms, if you're not racing, I'd suggest what we used to call an Audax or "fast touring" bike in the old days.
Posted : 16/05/2018 9:02 pm
You want a Mason Definition.
Posted : 16/05/2018 9:10 pm
I do and mine is definitely an all out CX race bike, it's a KTM Canic CXC. It's got 1x11 with 42t up front and 11-36 Out back. Roughly the same as 50/14 and 34/28 so standard compact gearing with a bit missing at the very top.
I've currently got 30/32mm Specialized Roubaix Pro 2bliss on it set up tubeless and they're seriously quick on the Cheshire lanes I ride. On my commute (52-60km depending on route) I can average 30kph.
It's just as comfortable as a road bike, if not more so, it's just as fast and stops brilliantly due to the discs, even with diddy 140mm rotors.
You can replicate pretty much any bike set up position with the correct choice of stem, bars, post and saddle.
Posted : 16/05/2018 9:38 pm
I've been using a Kinesis Pro 6 as my only road bike for several years now. I don't do that much road riding nowadays on account of not wanting to increase my chances of dying under the wheels of a BMW or something, but when I do (mostly in winter when the trails are completely trashed) it seems to do the job just fine. It's comfy enough, has mountings for actually functional brakes, can take proper mudguards, has space for relatively sensible sized tyres and can easily cope with a little bit of the National Cycle Network's optimism towards what constitutes a suitable surface for cycling on.
I have also done CX races on it, by the way. CX races are bloody horrible, don't make that mistake.
Posted : 16/05/2018 10:54 pm
Same here - the G-Ones are brilliant.
Posted : 17/05/2018 8:02 am
So until I read the bit about your back I would say a real road bike.
I have a giant anyroad with a massively high bar position, it’s soooo comfortable, 2 sets of wheels one for true gravel riding G ones again, one for road only rides with roadie mates.
Yes I have to push harder with my roadie mates, but if speed is not top of the list and comfort is, gravel is the way to go over cross over road.
Posted : 17/05/2018 8:26 am
If you buy a bike (eg gravel) which will take larger high volume tyres, that will handle rough roads much better. The trick is finding a good tyre.
If you decide you don't like the fatter tyres, there's always the option of fitting thinner ones.
If you buy a bike that only takes skinny tyres, then your only option is continue to suffer on the rough roads.
Unless you are aiming at racing speeds all the time, the bike itself makes little difference, the tyre is what counts.
Posted : 17/05/2018 8:32 am
Exactly.  Presumably you already have the largest tyre you can fit on your current bike and if so what size are they?
And if the roads are really rough the bigger and heavier tyre could actually be faster even if it doesn't feel like it
Posted : 17/05/2018 8:50 am
I’ve got a CX bike, and then bought a road bike, marginal gains and mostly psychological but it is quicker and even on 25mm tyres it’s been ok on back lanes that are more like a gravel track than a road
Posted : 17/05/2018 9:01 am
I've a Spesh Roubaix road bike and a Genesis Croix de Fer commuter/canal tow path bike. If I was buying a bike now I'd get a gravel bike (or something like that) that could take 45c tyres and get a spare set of road oriented wheels. I don't ride in chain gangs or do sportives any more so speed and lightness being the absolute end-alls no longer apply.
I've got 37c tyres on my single speed and they don't feel much if any slower than the 28c tyres I had on there before, Strava times are in and around the same area, some are quicker, some slower but I could have had a tail wind on some segments, etc. The 37c (WTB Riddler) are much, much comfier and also mean if I want to use a bridleway or track then it really isn't a worry.
As someone noted above: gravel bikes are the modern incarnation of what we once just called "a bike". I wouldn't want to ride The Beast or Cavedale on one but then that's not what they are for.
Posted : 17/05/2018 10:07 am
 Aus
Thanks all and v helpful.  Gravel looks like a way forward on balance.  Re comfort, my bike is a good fit and 25c tyres are the max it can take.  The comfort thought was utilising fatter tyres, poss less stiff frame and maybe a slightly less prone body position rather than bike fit per se.  I have a lust after ti or steel frames, and secondhand is the only option, so any recos of what to look at would be great. The Ritchey Outback looks lovely but it'll be a few years before it appears on the secondhand market I guess.
Posted : 17/05/2018 10:27 am
Genesis Croix de Fer?
Posted : 17/05/2018 10:35 am
Bear in mind if you do go for a gravel bike you’ll also need to budget for 2 fat bikes to round out the quiver.
Posted : 17/05/2018 10:36 am
I have a Shand Stooshie, which is categorised as a gravel / adventure / all-road bike (delete as appropriate) and has fairly light wheels with 28c all-season road tyres at the moment.   The Shand was meant to replace my Surly Straggler, which is a similarly flexible but heavier frameset, fitted with burlier Hope wheels and Surly's own 41c tyres.  Both have full mudguards and can take racks etc for touring.
I used to run the Straggler with two sets of wheels, i.e. its current 41s and those 28s now fitted to the Shand, after I slimmed down my bike collection a couple of years ago.  Other than being a bit porky, I was happy with that setup - and it was my idea to continue with the format of 1 bike with 2 sets of wheels on the Shand.
However - 5 months after building the Shand - I'm still undecided whether to keep the Surly as a bad weather / singlespeed bike, re-build it into a more focused roadie, or just sell it!
Posted : 17/05/2018 11:16 am
 Bez
Sounds like a Cross Check might fit the bill (plenty of tyre clearance and a forgiving fork) with the caveat that if you're looking secondhand then you may struggle to find one with enough steerer to bring its traditionally low front end up to where you want it. (Unless you're happy with a high rise stem: not pretty but perfectly functional.)
The Truckers are similar, with a higher front end.
Posted : 17/05/2018 11:29 am
I bought my carbon-framed CX bike when the notion of 'gravel bikes' wasn't even a marketing wonk's wet-dream - it very light, but very stiff. However, running a pair of 40mm tubeless Schwalbe G-Ones @ 40psi makes it very comfortable and quick - only a touch slower than my road bike. It's perfect in these parts for all-round use - I can ride road, trails, towpath and bridleways. Bigger tyres also means that it manages fist-sized flints far better than regular-size CX tyres. Big tubeless tyres are awesome on a gravel-strewn, pot-holed and rough roads.
Posted : 17/05/2018 11:52 am
OP have you thought of bigger tyres?
That's going to be the main benefit of a cross/gravel bike
Posted : 17/05/2018 12:07 pm
I bought my carbon-framed CX bike when the notion of ‘gravel bikes’ wasn’t even a marketing wonk’s wet-dream – it very light, but very stiff. However, running a pair of 40mm tubeless Schwalbe G-Ones @ 40psi makes it very comfortable and quick – only a touch slower than my road bike. It’s perfect in these parts for all-round use – I can ride road, trails, towpath and bridleways. Bigger tyres also means that it manages fist-sized flints far better than regular-size CX tyres. Big tubeless tyres are awesome on a gravel-strewn, pot-holed and rough roads.
This, almost exactly covers me and my bike (except that I only bought mine a couple of months ago). I'm also running these tyres, but I'm finding that I can run them at 30psi and they still roll really well on the road (although I do stick a bit more waft in them if the ride is going to be mostly tarmac). For dirt at 30psi, the bike absolutely flies with a remarkable level of comfort and I've been delighted with the tyres, even if they are a pretty snug fit on my bike.
Posted : 17/05/2018 12:10 pm
I transitioned from a regular road bike to a gravel bike this year. I was mainly using the road bike for commuting which is a mixture of pot hole ridden country lanes, dirt paths and road. The skinny, high pressure tyres always gave an uncomfortable ride, so I bought the entry level Genesis CdA instead and put all my 105 components from the road bike onto it.
The gravel bike is so much fun, big tyres take all the road buzz out and don't even notice the pot holes now. I don't think I'd go back.
As others have said, it's not a speed machine ... but I can sit comfortably around 20mph, and have only added a minute or two onto my commute time. I need to change the gearing a little though as I'm currently running 44 x 11-32, and it's a bit harsh on the bigger climbs. I'll probably change to a 40/42 front ring and put a 11-36 on the back.
Posted : 17/05/2018 12:38 pm
It can be fun especially in winter with discs.
I’ve completed 50 mike road rides easily on my CX but it does restrict the speed with tyres, weight and 11x1 Rival is great but restrictive.
If I ride with slow friends then I bring my CX.
If you ride fast then no.
A double chainset with a lightweight frame absorbing bumps is a must.
If you cruise and like exploring and can have one bike only then yes.
Posted : 17/05/2018 6:23 pm
Wouldn't it be nice if all the niche drop-bar things kind of coalesced into a bike you could just ride without wittering on about whether it's a cross bike / gravel bike / touring bike / road bike with loads of tyre clearance etc.
On the single ring side of things, maybe for normal people, but I recently listened to an interview with one of the guys from Aqua Blue about racing with a one-by drive train and it sounded horrific with changes of chain rings and cassettes plus chains pretty much every day plus cassettes deliberately stacked at one end of the range so the jumps between gears weren't too savage. Maybe when they get up to 15-speed drive trains...
Posted : 17/05/2018 11:45 pm
If I had to choose just 1 bike to do it all – it would be the SuperX.
And it's gorgeous. One of the nicest I've seen. Cannondale really do go for a nice aesthetic.
Posted : 17/05/2018 11:56 pm
 grum
At the risk of hijacking, any particular reason not to buy this in the same kind of vein as what the OP wants? (unless one of you sneaks in there first of course). It seems to be usually described as a CX bike and has quite a bit higher BB than something like a Diverge, but I'm broke and I want to do some touring.
https://winstanleysbikes.co.uk/kona-jake-2017-bike
Posted : 17/05/2018 11:58 pm
I think it would do that job admirably
Alu fork might be a little harsh but that's relatively easy to upgrade and bigger tyres at lower psi will offset that. Otherwise, fundamentally sound.
Posted : 18/05/2018 8:07 am
 grum
Cheers jon - it's what I thought but good to have a second opinion. Gonna go have a look at them today to check for size.
Posted : 18/05/2018 11:58 am
Won't be any time soon, but I am definitely gonna go 1x for my next gravelly type bike. If I can afford it, SRAM eTap road shifters with eTap Eagle MTB rear mech sounds perfect (not that it's an option just yet!!)
Posted : 18/05/2018 1:52 pm
 Aus
It's funny having started this thread, it played on my mind on today's road ride, Kentish lanes around Hever. I really enjoyed the zip of my Airborne and the lightness, but a lot of concentration was spent on avoiding ruts and potholes.
A roadie friend said it was relatively quick but for me, that's not the point. I want to cruise along, fast or slow and enjoy the fantastic countryside, feeling of movement, energy without worry. It sounds like a bike that can take fatter tyres will be a significant improvement. My bike is prob 25mm max. Where does the fatter tyre width really start to kick in for comfort.
Posted : 18/05/2018 6:36 pm
I managed to pick up a heavily discounted Cannondale Slate Ultegra in February. I absolutely love it for commuting, exploring the South Downs on road and less harsh trails and I have also done a couple of 40 mile road rides on it with Schwalbe G-Ones. It is slightly slower than my road bike, but not enough to concern me anymore. As a consequence I have not ridden my Planet X Ti Pro Road since (Quite a bit is as I have got bored of road riding and wanted to get back offroad more, but I am riding it as much as my carbon hardtail at the weekend)
Posted : 18/05/2018 7:12 pm
 grum
If anyone's interested I picked up the cheap Kona Jake 2017 from Winstanleys today - really pleased with it especially for £600. Might swap the tyres for something semi-slick and the brakes don't seem amazing but it felt really nice on my brief ride around the car park. It looks really good too.
Can't wait to get some panniers on it and do some on/off-road touring.
Posted : 18/05/2018 10:54 pm
I tested the canyon with funny bars last week and what an amazing bike it is . It was top end model , DI2 and carbon everywhere but if I had budget I would get one with 2 sets of wheels .
Posted : 18/05/2018 11:11 pm
