Upgrading a Patriot...
[Closed] Upgrading a Patriot 66. Advice please
 GEDA
[#3911070]
Ok, I have a patriot 66 that I want to upgrade. I already have a pair of Marzocchi 55 rc3s that I was going to put on it but would anyone like to recommend a new shock for it? The dimensions are 215mmm i2i x 63mm stroke or 8.5" x 2.5". Or 200 x 57 According to this thread http://singletrackworld.com/forum/topic/patriot-66-shock-info
I do not mind if it is coil or air but do not want to spend too much money.
I was looking at locos dueler shocks http://locotuning.co.uk/dsp-dueler.html for £275. I stopped using the frame and got a MX Prophet (Now a bit sick of the bolt through back end on the prophet) as the Pratriot was a slow on the flat (No problem going up or down) so it would be nice to drop a bit of weight. I can also remember the damping/rebound was not that controlled. It currently has a Manitou Swinger Coil 3 way on it.
Another thing is what are the differences between this bike and say an Orange Alpine? Is it weight/angles or in the real world is there not much difference and it would be better with a new shock.
Posted : 25/04/2012 12:16 pm
 GEDA
There also seems to be some decent offers here to: [url= http://www.mojo.co.uk/clearance.html ]http://www.mojo.co.uk/clearance.html[/url]
Posted : 25/04/2012 12:19 pm
I've a Diverse dueler on my 66, and it rocks!
Posted : 25/04/2012 1:01 pm
 GEDA
Is it bobby, how much does it weigh and do you get the bushing hardwear when you buy it?
Posted : 25/04/2012 1:02 pm
my reckoning is that a patriot will be ace with a 190x50 rp23 fitted on the standard shock shuttle to lower, slacken, lighten and firm up should give 140mm which is enough for most UK duties. I'm going to try the shock out of my old sub 5 for a while and see what it runs like.
The 200x57 dhx air from mojo looks a good deal though...
Posted : 25/04/2012 2:40 pm
I thought Orange used to produce a separate shock shuttle that could replace the original thereby keeping the standard geometry but shortening the travel.
This would have the effect of turning it into a beefed up 5 (sort of). Whether they are still available is another matter.
I just put a 2nd hand DHX 5 on mine and that suits me just fine.
Posted : 25/04/2012 3:36 pm
 GEDA
Will have a word with mojo then. Do the DHX shocks need a specific tune like the RP shocks?
Posted : 25/04/2012 3:48 pm
 LoCo
Ran a heavily modified DHX coil on mine a few years ago when I had them.
The Dueler will work nicely on the 66 with a bit of tuning that I can do at time of purchase.
Any further queries don't hesitate to drop me a mail. 😀
Posted : 25/04/2012 3:50 pm
but fitting the shorter shock with the standard shuttle ought to enhance the geometry 🙂
The DHX 5.0 has a lot of adjustability - i'd try it out first before deciding it need a specific tune. I don't think they're shock tuners favourite anyhow.
Posted : 25/04/2012 3:59 pm
 GEDA
Sent a mail loco. When are the 200X57 shocks in stock?
Posted : 25/04/2012 5:47 pm
It's not bobby at all, just really really active! I don't really know about the weight and can't remember if It came with the hardware or not, sorry.
Posted : 25/04/2012 6:11 pm
 GEDA
Did some research and it looks like the old patriot is between the Five and the Alpine. I think the patriot 66 bare frame is about 2.65kg compared to the Five of 2.3kg? So not that much weight difference. Fancy putting the 200x57 shock on it.
Five
Frame Size 16" 17"
A. Head Angle 67° 67°
B. Seat Angle 73° 73°
C. Top Tube 557 570
D. Effective TT 582 602
E. BB Height 335 335
F. Chainstay 425 425
G. Head Tube 130 130
H. Wheelbase 1116 1140
T. Rear Travel 140 140
Shock Length 190 190
Seat Tube Ø 30.9 30.9
Standover 716 735
Patriot 66 2006 16".
Frame Size 16"
A. Head Angle 67°
B. Seat Angle 72°
C. Top Tube 550
D. Effective TT 577
E. BB Height 365
F. Chainstay 432
G. Head Tube 120
H. Wheel base 1122
Alpine
Frame Size 16" 18" 20"
A. Head Angle 66.5° 66.5° 66.5°
B. Seat Angle 74° 74° 74°
C. Top Tube 559 577 601
D. Effective TT 580 600 620
E. BB Height +6 +6 +6
F. Chainstay 435 435 435
G. Head Tube 130 130 150
H. Wheelbase 1153 1173 1193
T. Rear Travel 160 160 160
Shock Length 215 215 215
Seat Tube Ø 30.9 30.9 30.9
Standover 724 762 800
Patriot
Seat Tube length355 409 459
A. Head Angle 65.5 65.5 65.5
B. Seat Angle 74 74 74
C. Top Tube 546 560 577
D. Effective TT 560 580 600
E. BB Height +8 +8 +8
G. Head Tube 105 120 120
H. Wheelbase 1140 1163 1183
T. Rear Travel 180 180 180
Standover 760 770 784
Fork length 560 560 560
Fork offset 40 40 40
Posted : 26/04/2012 8:36 am
