Patriot 66 shock in...
[Closed] Patriot 66 shock info
[#2434147]
Trying to find the shock size (eye to eye) for a DHX3 coil. Seems to be a 2.8" spring, but short of taking the bike off and measuring, there must be data out there.
Any suggestions would be gratefully received. And yes, I did try googling, even rang up TFT. Someone must know this, surely?
Posted : 03/02/2011 11:38 pm
I am sure its 215mmm i2i x 63mm stroke or 8.5" x 2.5"(same as the Alpine 160). However, I think you can use a 190 x 50 shock in certain shuttle positions for a shorter 140mm travel. Hope this helps.
Posted : 03/02/2011 11:57 pm
fivespot is correct 😉
Posted : 04/02/2011 12:55 am
Phone Orange???
Posted : 04/02/2011 8:09 am
+1 Five spot is correct 🙂
Posted : 04/02/2011 8:29 am
Cheers all, just what I needed.
Posted : 04/02/2011 9:24 am
215mmm i2i x 63mm stroke (8.5" x 2.5") is the standard size and will give you 178mm (7") of travel. You can run a 200mm i2i x 57mm stroke with the same shock shuttle to give ~160mm travel. From what I remember you could run the shock shuttle flush with the end of the shuttle mount with the shorter shock and it's nicely slack and low. You can also run a 190mm i2i * 50mm stroke for ~140mm travel but you'l need the angled shock shuttle for that.
Hope that helps.
Posted : 04/02/2011 9:48 am
yup, agree with everyone. I've had a 215mm shock, a 190mm shock with the short shock shuttle, and have now settled on a 200*57 for 160mm front and rear and that seems the best all around bet for me. Although, it was a lot of fun with 190mm on it, you could set it up very slack and low at the bb and it ripped around.
I liked it least with a 215mm on it actually.
Posted : 04/02/2011 11:26 am
