Uninvited rider on ...
[Closed] Uninvited rider on your wheel
[#1036034]
Happened again this morning, just pedalling into the Queen's Park, pass some duffer on a singlespeed/fixie, chain and yellow waterproof flapping in the wind, I'm going 4mph faster so just pedal past, look round a few 100m on and he's 6" from my wheel 🙄
I pressed hard on the pedals and whaddya know he couldn't respond. Are these the same guys that do 45mph on single carriageweays then 80 on dual?
Posted : 13/11/2009 9:58 am
I had a guy do this the other night, passed him then he caught up as I slowed for the next set of lights then sat on my wheel. I pulled away from him for a bit but even when I slowed right down waiting for the lights to change he still sat there - he pulled alongside me as he was doing a left turn and said, 'Sorry but I'm a slipstream junkie'. No you're not, you're a fanny.
Posted : 13/11/2009 10:03 am
why do people get so het up about this on the commute? Is it perceived danger, or is it somebody getting a free ride?
Posted : 13/11/2009 10:04 am
 xcgb
Helps if you can fart like a docker!
Tap the brakes lightly so he/she will have to respond. They should get the idea soon enough, This works in the car as well, a small tap to bring the brake lights on and people soon drop back..
Posted : 13/11/2009 10:06 am
Happened to me a few years ago and I am slow .
but into a huge head wind I did not know he was there untill about 5 seconds after I had gobbed a green lung slug over my shoulder 😆
Posted : 13/11/2009 10:07 am
vinneyh - it's a safety and etiquette issue for me, I've been rear ended before.
Posted : 13/11/2009 10:14 am
get over yourselves!
'etiquette issue'
so tapping the brakes and changing speed isn't? They really aren't doing any harm. In fact they're helping you out aerodynamically.
Grumpy bloody commuters, cheer the hell up!
Posted : 13/11/2009 10:16 am
[i]They really aren't doing any harm[/i]
until they ride into the back of you, of course.
slow down a bit till they end up half-wheeling you, then put a pump through their front wheel. Either that, or snot rockets.
Posted : 13/11/2009 10:20 am
I don't normally mind if somebody wants a tow but had a nasty experience on a commute a couple of years back on a wet potholed road- I swerved to avoid a water filled hole- the guy behind me didn't know the road, must have put his front wheel in it- I heard a yelp, looked around and he was down. 🙂
Posted : 13/11/2009 10:21 am
I have no problem with it at all, probably because I'm inclined to do it so it's give and take.
I have never been rear-ended before, but if someone tapped their brakes for no reason in front of me I'd be extremely tempted to pull my own unnecessary manoeuvres...
 GEDA
You could do some wacky races type thing like a special box that is full of drawing pins or oil that you pull a string and kaaboom they get it full on slipping on your dastardly oil slick or pop pop pop as their tyres deflate at an alarming rate as you cycle off triumphantly into the distance.
Otherwise you could just rant on a forum and get over it /treat it like a race.
Why not give them a tow and then slow down and make them do a turn? Everyone's a winner.
Posted : 13/11/2009 10:22 am
I doubt the scaredy moaners on here have much experience of through and off, they'd prefer to take someone out "by accident" and brag on here like the real men they are.
Posted : 13/11/2009 10:25 am
I caught a proper roadie a few weeks back, he was slipstreaming me on my roadrat-he was on a cervelo. I tapped my XT disc brakes and he hit me hard enough to brake my mech off and give me whiplash. The £13 k (estimated compo) should get me a Cervelo too....
Posted : 13/11/2009 10:29 am
You never watched any team time trials? just pull out & drop in behind him. He should get the idea.
Posted : 13/11/2009 10:30 am
I wouldn't want to risk rear-ending them as they tap their brakes....
Posted : 13/11/2009 10:32 am
Snakebite, did you have a reason to brake?
Posted : 13/11/2009 10:33 am
[i]Snakebite, did you have a reason to brake? [/i]
does he/she need to have a reason to brake?
Posted : 13/11/2009 10:34 am
Sitting on someone's wheel in busy traffic really isn't a sensible thing to do, I have far to many other concerns in traffic without thinking about someone 2mm from my arse. It's nothing to do with grumpiness.
[i]just pull out & drop in behind him[/i] Not really an easy move in busy traffic.
Posted : 13/11/2009 10:35 am
It's a pretty malicious thing to do in my opinion if there's no reason to brake, and calculated to cause an accident. Wouldn't it have been more sensible to have a word with them, or to slow down for a moment and let them past.
Posted : 13/11/2009 10:37 am
If they are slipstreaming you they are riding far to close for safety - I'd just tell them where to go.
Posted : 13/11/2009 10:40 am
[i]It's a pretty malicious thing to do in my opinion if there's no reason to brake, and calculated to cause an accident.[/i]
Indeed. And yet the rider in front is perfectly within their rights to brake wherever and whenever they wish. If the rider behind isn't used to holding a wheel and watching for sudden braking, they shouldn't be that close.
Is this a roadie/mtber thing? Do any of the people who have strong objections do club rides on the road?
Posted : 13/11/2009 10:41 am
 D0NK
Yeah I dunno why you get so wound up by it, if I pass someone and they tuck in behind I'll give them a tow and point out pot holes etc to them for a while then I'll make sure they take a turn up front. Same if someone passes me, I'll tuck in for a while then offer to go upfront. Obviously you don't do it through traffic but on normal roads getting rear ended is unlikely I'd have thought.
Of course snakey had a reason to brake - he needed a new mech.
Where there's blame there's a claim.
The other day, coming back from town with a pannier full of groceries, weighing me down I overtook a local keen roadie going up the railway bridge. (Because you can't ride up hills slowly on a fixie - it doesn't work).
Naturally, I had to maintain the pace all the way home, nearly killed me. As I turned off into my drive I allowed myself to look round - the bugger wasn't there! I was sure he'd been on my wheel but he must have stopped at the letter box or something.
Posted : 13/11/2009 10:42 am
I could understand if you were 5 years old or retarded that it might be an issue having someone cycle close behind you, otherwise get over yourselves you whining muppets...
Posted : 13/11/2009 10:43 am
Why should I accept someone riding too close to me and putting me at risk? I have no idea the level of their skills
Posted : 13/11/2009 10:44 am
I'm sure that the rider in front is culpable (as well as a c**t) if it is proved they braked for no reason whatsoever. When I sit on a wheel, I don't focus on the rear tyre in front, but past the rider so I can know when to brake.
I'd love to see the moaners in a road or track race, they'd absolutely crap themselves 😯
Posted : 13/11/2009 10:45 am
 Sam
Agree with full stop and others, it's about safety both for you and them. Anything might cause a panic stop or sudden maneuver to avoid road debris etc. If someone is friendly and says something then I don't mind if they seem competent and you are riding at a similar speed - riding as a pair, or even more, is fun. However if someone just pulls up behind you and sits on your wheel it's not only rude, but dangerous. Besides, if you are going fast enough to catch someone you should be able to go past them and let them sit on your wheel. This also allows for an introduction and mutual consent -it's what makes for a good partnership...
[i]Do any of the people who have strong objections do club rides on the road?[/i]
plenty thanks. Usually the people on club rides know they're each on a club ride, and know there may be someone on their wheel, who knows how to ride on a wheel, and who will do a turn if they are able.
Posted : 13/11/2009 10:46 am
[i]When I sit on a wheel, I don't focus on the rear tyre in front, but past the rider so I can know when to brake.
I'd love to see the moaners in a road or track race, they'd absolutely crap themselves [/i]
so you know how to sit on a wheel - that's great. In which case, you'd be more than welcome to sit on my wheel whether on my commute or in a road or track race (if you can keep up 😉 ). Problem is that not many people DO know how to safely hold a wheel.
Posted : 13/11/2009 10:48 am
Just wind it up and drop their arse off the back. Braking is uber ghey.
I've seen and heard of plenty of crashes on club runs, doesn't mean the riders know how to ride a bike just beacuse they can meet at a crossroads at 9.30 on a saturday morning!
Thanks, I'm sure I'd keep up 😉
Posted : 13/11/2009 10:49 am
[i]I've seen and heard of plenty of crashes on club runs, doesn't mean the riders know how to ride a bike just beacuse they can meet at a crossroads at 9.30 on a saturday morning! [/i]
indeed. But at least on a club run you're expecting to be riding in a pack.
Posted : 13/11/2009 10:50 am
true enough. Could be argued that you'd expect the same in London now too!
Posted : 13/11/2009 10:52 am
[i]If they are slipstreaming you they are riding far to close for safety - I'd just tell them where to go.
[/i]
what if he wasn't wearing a helmet?, surely he'd be riding within himself and by not wearing the helmet he'd be avoiding an accident by not doing things that were out of his depth, your theory i gather
Posted : 13/11/2009 10:53 am
[i]Thanks, I'm sure I'd keep up [/i]
fancy a 2-up some time? always on the lookout for a fast partner 😉
Posted : 13/11/2009 10:54 am
I'm fast, so if I detect someone behind me like this I kick on a bit.
If they're still there after that, and not clinging on for grim death, I assume they're comfortable riding at that speed and figure its a fair assumption they know what they're doing enough not to needlessly endanger either of us. On the roads I try and ride as though there's a car sitting right behind me anyway and avoid sudden changes of speed or direction wherever possible.
No problem at all with the principle of someone getting a tow from me, which is what I suspect is behind more than a few objections to this practice. Same when I'm out on a proper road ride, really.
If your riding your bike on a conveyor belt. Should the rider behind leave a bigger gap if they're not on the belt?
Posted : 13/11/2009 10:59 am
well put 2 tyred.
Anybody of the objectors practice brake testing of cars that are following you too closely, or would you only do it when it's somebody else likely to get hurt? Or how would you feel if the car just in front of you on the commute took objection to your presence and braked suddenly but needlessly?
Posted : 13/11/2009 11:02 am
2tyred, I'd say that was a good assumption!
AndyP, I'm more of a bunch sprinter (probably why I like sitting on any wheel I can find!), what are your lead-outs like?
Depends on the circumstances. In busy traffic it's bloody dangerous - I wouldn't do it to others and I don't expect them to do it to me. A quiet word is usually all it takes. I'd never deliberately bring anyone down, that's the absolute height of stupidity and I hope the people on here saying "hit the brakes" are only joking.
Out on a normal road ride on quiet roads then yes, I've got no problem with slipstreaming - it helps out both parties and it can be quite social too.
Posted : 13/11/2009 11:03 am
Wow. I was semi-trolling, noce to see the common view isn't so anti-cynic as perviously.
I suspect all those saying "chill out man" etc haven't seen a bunch get taken down by one careless rider...
Posted : 13/11/2009 11:04 am
Page 1 / 3
