Uberbike bb bearing...
[Closed] Uberbike bb bearings help
2 Users
I need to replace the bearings in my uberbike Dub BB however it looks like they have them made and don't tell you the bearing code.
The bearing has 2940rv stamped on it.
Does anyone know what the actual bearing code is so I can get some from any bearing supplier?
Posted : 18/08/2021 11:32 am
If you can get one out and put the measurements into a suppliers website, (Simply Bearings is a good one) that should pop you up a lot of options. You'll just need to pick the right type, (which is likely deep groove ball bearing) and seals.
Posted : 18/08/2021 12:40 pm
