Tyre recommendation...
[Closed] Tyre recommendations needed - but not the normal "what tyre for ..."
[#3853058]
Mrs M is wanting to get fitter and is going to give a bike another go. She tried some time ago but didn't really get going - this time she has a friend who she can cycle with so hopefully there will be more motivation
I have a very old Stumpjumper HT that I've got going and put a lady's saddle on, but need to get some new tyres. She's only going to be doing roads and good LR tracks, and she's not into speed or steep climbs, so, your suggestions please on something that will be nice and fast rolling and feel safe for her
Posted : 09/04/2012 6:47 pm
Kenda SB8's, Michelin Dry's, - basically anything that hasn't got any real tread on it would suffice I would think....?
Posted : 09/04/2012 6:52 pm
Schwalbe Landcruiser. It has a nice wavy "centreline" to make it fast rolling but still has knobbly edges for grip in the loose/wet stuff.
I am well impressed on LR tracks by mrs_oab's weeny Vulpine SL's - really supple and surprisingly grippy for what looks nearly a slick...they also go whooooooooooooooosh fast. As with Landcruisers, some edge on them when needed. Cost £10 of classifieds...
Posted : 09/04/2012 7:02 pm
Maybe a maxis crossmark, so if it's only used a few times it will be of use to you?
Posted : 09/04/2012 7:10 pm
Any semi slick, with a decent carcass.
Posted : 09/04/2012 7:11 pm
Schwalbe Rocket Ron Performance 2.25" at £17.50 each at On-One sale.
Voluminous for some suspension, light (approx 520g) and not too grippy/low rolling resistance.
Or, SB8s at a higher price and awful/useless/exciting in the mud.
PaulD
Posted : 09/04/2012 7:21 pm
Thanks guys. So I'll check out
Kenda SB8
Michelin Dry
Vulpine SL
I like the idea of that almost slick centre section but with grip on the outside for a bit of confidence if the track gets a bit loose
Probably pass on the Rocket Rons as I think a skinnier tyre will have less rolling resistance
Any other mega suggestions before I push the button on one of the above?
Posted : 09/04/2012 7:29 pm
CM,
Pass on the Rons if you wish, but do it for valid reasons.
Rolling resistance is far more complex than just compound or tread or size.
A hardtail needs a voluminous tyre for comfort...I have experimented (and dismissed) Kenda Klimax-Lites which are claimed to be 1.95 but are nearer 1.5 inflated. Fine on tarmac and hardpack but deficient off-road.
PaulD
Posted : 09/04/2012 7:38 pm
"almost slick centre section but with grip on the outside for a bit of confidence if the track gets a bit loose"
Id have thought if confidence is an issue she'll not be leaning the tyre/bike over to get that outside tread to really bite?
Something with some low (rather than almost nothing) tread might be better?
Personally I found tyres with near centre-line-ridge-type tread, like maxxis crossmarks although rolled quite well could slip out under breaking/pedalling (okay a fair bit of) and I never really trusted them in the loose or to corner on properly
My Michelin Dry2's are maybe a touch lower tread but dont have a centre-line and I find (in the dry and not too loose) to be more predictable and trustworthy all round, while being almost as good rolling.
On-one have the folding 2.15" dry2's for £10 atm (as big as 2.25" maxxis (bigger than 2.35" maxxis), slightly bigger than 2.25" schwalbe)
The 2.0" versions are better rollers though, being a bit lighter/smaller, but still big for a 2.0"
They are still an offroad tyre, so not anything like slick quick on the road
" I think a skinnier tyre will have less rolling resistance"
On a (smooth) road/smooth surfaces yes, in the rough I believe not so, a fatter tyre more easily 'deforms' to rough surfaces so rolls better, or so Ive read
Posted : 09/04/2012 8:11 pm
PaulD, good point about the tyre volume as Mrs M does find the bike uncomfortable
james - good point about predictability as she is a nervous rider
Hmm, so reasonable volume with a low tread pattern - so which of the above would that be?
Posted : 10/04/2012 3:00 pm
I found the Panaracer Mach SS good on the road and still quite good on a dry trail
Posted : 10/04/2012 3:07 pm
 mboy
Michelin Dry2's for definite. As quick as a semi slick, still offer decent grip offroad (unless you're riding in mud obviously), they're pretty light and they're ridiculously cheap from On One right now. Have run a pair of 2.3's for a summer before, front and back, only ended up taking them off when it got muddy in November, and never found them wanting except under braking on very steep terrain (lack of large centre blocks to hook up with), but otherwise excellent.
The 2.3's are big, and have reinforced sidewalls, the 2.15's are still big but a bit more sensible and are quite a bit lighter.
Posted : 10/04/2012 3:08 pm
I found the Michelin's to be large volume and much bigger than the stated 2.0
Posted : 10/04/2012 3:09 pm
Specialized Fast Trak?
Other half has them on her Myka hardtail and seems happy enough with them.
Posted : 10/04/2012 3:22 pm
Thanks all. Having looked at the tyres and a few reviews, I reckon the Michelin Dry 2.15's are the choice as they have a bit of tread and sound big enough to give a bit of comfort. And at £9.99 each from On One (thanks mboy and james) they are a steal
Posted : 10/04/2012 4:29 pm
Whats an LR track?
Continental Travel contacts are very good IMO. Smooth centre section with water grooves and then side knobs for grip in rough / muddy stuff.
Used them for commuting in snow and they were fine, as well as a fair bit of mixed on / off road bike touring with some proper off road ascents / descents fully laden with panniers so plenty of grip. Also the 'ProTection' does a good job of keeping punctures at bay - i didn't get one in 2 years of use
Posted : 10/04/2012 6:40 pm
Pieface - Member
Whats an LR track?
Landrover track. Thanks for the suggestion, but Mrs M won't be venturing on to rough/muddy stuff in the near future.
The Michelin Dry 2's now ordered from On One at £10 each
Posted : 10/04/2012 7:05 pm
