U turn spring assem...
[Closed] U turn spring assembly swap
[#3853076]
Hi guys, I have a pair of 85-130mm revs, can I replace the u turn spring ass with a pike/ newer rev 140mm one ? Thanks
Posted : 09/04/2012 6:50 pm
Nope. It might fit, but you'll be preloading the spring to get it in there. Forget the idea if I were you
Posted : 09/04/2012 7:11 pm
 LoCo
No, the damper unit is for 130mm travel so as Poddy says you have to 'squash' the spring assembly in.
Posted : 09/04/2012 7:15 pm
Ok thanks guys 🙂
Posted : 09/04/2012 9:13 pm
 GW
Why can't he simply wind the Uturn down so it matches the length of a rev spring assembly? Granted it might not give as much travel if the new spring bottoms earlier.
Posted : 09/04/2012 9:23 pm
