Just bought a fat bike. Can anyone recommend a suitable low pressure tyre gauge. Mine isn't accurate enough for the low pressures.
SKS Airchecker if you want a digital one http://www.chainreactioncycles.com/sks-airchecker/rp-prod29977
Digital = Topeak Smarthead d2.
Analogue = Accu Gauge low pressure (choice of 0-15 or 0-30psi).
Topeak one is spot on, not tried any others but then I guess why would I when that one is perfect for the job.
"Accu-Gage" gauge
Available on ebay from the USA for about £18 including postage.
[url= http://www.ebay.co.uk/itm/Accu-Gauge-Fat-Bike-Tire-Presta-Valve-Dial-Low-Air-Pressure-Gauge-Max-15psi-/322004932237 ]0-15 PSI[/url]
[url= http://www.ebay.co.uk/itm/Meiser-Accu-Gauge-Fat-Bike-Tire-Presta-Valve-Dial-Air-Pressure-Gauge-Max-30psi-/222000597371 ]0-30 PSI[/url]
I bought a 15 PSI one from that seller last year, and it arrived in about 10 days - no problems at all. Ideal for a fat bike.
[url= http://singletrackworld.com/forum/topic/tyre-pressure-gauge-who-uses-one ]More opinions...[/url]
I was looking for one about a month ago. ALL the digital ones have VERY mixed reviews if you look around. Ended up going for a good quality analogue schrader gauge and some presta adaptors. All for a tenner less than the D2. Works well.
EDIT ^^^^ The Accu ones are supposed to be very good, if you don't mind the wait.
Just to add I've got both the digital and analogue that I recommended.
Although it's the analogue that is my 'go to' for the fat bike.
