Vaguely looking at a very good deal on a Turner Flux...
Quite fancy a short travel bike (and not many go small enough for me) but is the Flux fun to ride downhill too, or is it all about speed and efficiency??
Cheers!
I ride mine up, down, flat, i had an xce before again with just under 4 inches of rear travel took that to wales, scotland, lakes, peaks and spain never felt that it was to smaller a travel for the downhills, would do a world cup downhill course but not at speed though
wow that made sense?.... ๐
sorry still tired from last night, the flux is fast and a great climber, i had my shock "pushed" and that made the rear slightly more supple, i can fly downhills, although i have not tried a real downhill bike so can't compare but i have yet to come across anything i couldn't ride down. I have 120mm maxle rebas on the front and 745mm wide bars and run tubeless, the only limiting factor in downhilling is my skill levels and fear
had a tnt flux very capable trail bike, used in y dales lakes and it wass fine, see the link for an alternative and have a look at dave turners comments
[url= http://forums.mtbr.com/showthread.php?t=584065&highlight=all+mountain+flux ]null[/url]
very intresting
I've a Flux DW and I built it up with no intention to racing or speed/efficiency...more for just plain fun and a bit of enduro/marathon. When think racing as well, by today standards (CF frames etc) the Flux is not that light...came up bang on 6.0lb for just the frame.
For mine it was wide bars, short stem, dropper seatpost and Reba U-Turns. Was tempted to stick a pair of Rev U-turns (100-130mm) but the Reba suit it perfectly...didn't feel it needed anymore travel at the front.
It's a great bike. Fast and stable on the downs particularly given the low BB, great on the Surrey Hill trails and climbs very well. It's not perfect imo...the travel is very plush but I find it goes through it quickly and I bottom out quite a bit if I find more technical descents or trails where you're getting off the ground. You could of course up the shock pressure which I have tried but the plushness goes and so for the vast majority of a ride you losing that benefit...better to have the odd bottom out imo.
Worth the money over say an Anthem X or Trek EX8? Well I've had an EX8 and had other FS frames (Ellsworth Truth, SC Superlight) and personally I'd say no. Lovely frame, great quality and good support and that's worth something plus the discounts around are good.
Vondally's link makes interesting reading.
My only direct back-to-back comparison against a similair suspension system was a 5 spot against a giant trance X and the turner was certainly worth the extra, the suspension worked much better. I have also tried an anthem (not x) and that was ok but not as stiff or plush. The flux can be had for only about 300 more than an anthem x frame would cost, if you can find one.
Its one of the better all rounders i would say.Put a 120mm fork on for a lightweight trail bike or 100mm for more race duty's.I am using it as a race bike and its fantastic! I have an older 5 Spot for mucking about on!
Thanx Max
nuke - dunno if it affects you but on my 09 dw-link flux the main pivot was a little larger in diameter at the outside than it should have been which meant the suspension was a little stiffer than it should be - when I set it up for the correct sag the actual pressure I used was a little low and therefore I got pedal strikes and bottom outs easier. When I changed the pivot (free from Greg) I could put
40psi more pressure in the shock.
I also use the enduro needle eye bearings instead of the DU busings on the shock mount and it is plusher still, so might help you run higher pressures.
http://www.enduroforkseals.com/id275.html
Sorry if I am talking to the converted - you probably ride a lot more aggressively than me (with that forum name) and certainly more aggressively than I will be riding next year after 5 months out with a broken collarbone ๐
I love mine. Only had it a bit so the only proper rides I've done was a frozen weekend at Afan. I consider it more of a trail bike really. Especially with a 120mm fork. It fits me better than my last bike(blur) longer and lower. I felt much more confident in ever aspect of my riding, especially on the downhills.
Cheers for that Turnerguy... given what you've said, can't hurt to give it try and replace the main pivot particularly if its FOC.
Don't be fooled by the username as I'm far more slow and steady wins the day ๐ ....username was just a retro throwback to nukeproof which I then shortened after they were re-born by Hotlines.
Dave Turner said on the mtbr forum that with the top shock bolt undone and the suspension fully extended you should be able to push down on the saddle with one hand to compress the suspension.
The 2010 version had an upgraded bushing with the shock which made things move easier than the 09 (both standard Fox RP23 bushings) but the needle bearing kit is better.
Think I started out with 120lbs and went up to 155 or 160.
What difference does having the top bolt undone make?
mudmonster - MemberWhat difference does having the top bolt undone make?
So that the shock is not connected and you can move the linkage independently
Is this thread broken?
or has the (dw-) links broken???
It's a problem with the STW server - it's been happening to lots of threads. See the sticky at the top of the form page for an explanation. Cheers!
