Turner 5 Spot, drop...
[Closed] Turner 5 Spot, dropping chain
I dropped the chain a few times on my new (to me) 5 spot at Glentress on Saturday.
I run 2 x 9 and each time the chain dropped onto the granny ring. The first time it did it resulted in a rather sore knee - gear lever interface.
Does anyone who rides a 5 Spot have these problems.?
Short of buying a chain device is there a way to stop it happening?
Could it be as simple as chain length and front mech height?
It a 2009 5 spot so it doesn't have ISGC tabs
Posted : 22/04/2013 5:35 pm
It's of little use to you, but I ride a 2009 5 spot with 2 x 9 (22/36) and I can't recall this happening.
Posted : 22/04/2013 6:02 pm
Actually it leads me to believe it might be my crappy drive train set up rather than the bike so yes it helps ๐Ÿ™‚
Posted : 22/04/2013 6:15 pm
Depends on the kit you're running. Is it a specific 2x9 front mech? If not, it's already standing higher off the rings than it should be.
Posted : 22/04/2013 6:17 pm
Rich, i have had my 5 spot for well over a year and the only time this has happened was when i was doing the Innerduro and the bike was bouncing all over the place.
Check that the Bottom bracket only has 1 spacer on the drive side, the chain is the right length and the front mech is 3mm up from the outer chain ring. If its all good from there i don't have a clue what to suggest.
 lamo
http://www.pinkbike.com/news/Tech-Tuesday-Chain-Length-Basics-2012.html have a read of this mate
Posted : 22/04/2013 6:54 pm
Have you cut the interference piece off the front mech? Connects with the frame during compression.
Paul
Posted : 22/04/2013 7:23 pm
I used a SRAM mech that as top pull only. The chain length looks fine too
Posted : 22/04/2013 7:59 pm
