Turbo trainers - re...
[Closed] Turbo trainers - rear wheels
[#3432832]
For Mrs S you understand. I dont bat that way.
Picked up an eBay trainer for a song this weekend, and tested it out. All seems fine. Im concious that she's going to be putting a fair few hours in on a fairly decent back wheel & block not going very far.
Does it make sense to buy/build a crappy rear wheel with freehub and use the ultegra block that goes with the chain and chainrings, or swap for a cheap block and chain and hope the chainrings dont get shagged?
What makes the for the best rubber too? Cheap and nasty? something with a tread to keep a consistant feel (slicks seem to slip a bit during power phase of crank stroke)
Or sod it and just go with the planet X model Bs that are on there and make her save up for some new carbon clinchers for when the daylight returns?
Posted : 06/12/2011 5:26 pm
go for one of the turbo specific rear tyres - they make the whole thing quieter, and run cool so you can run the contact nice and firm for good grip without peeling the tread off a road tyre.
i'd be tempted to run big ring and a midsize rear sprocket to spread the load, then not worry too much about wearing the block. probably easier to shift the block onto a cheap rear and leave the tyres seated, unless the bikes going on and off the TT a lot.
if you're going to be switching thing often, then go for a cheap rear and new cassette, so long as the chain isn;t really worn. a cheap new block won't do your chain any harm, although a part worn chain will wear the new cassette a little (unless it's so worn that the chain skips).
Posted : 06/12/2011 5:32 pm
cheers sp.
so a trainer specific tyre*, a cheap wheel and either a cheap block and use the existing chain or just put the good block on and be done with it. The bike will live on the trainer for the next 3 months without coming off.
* cheap recommendations?
Posted : 06/12/2011 5:34 pm
I've just hopped off the turbo trainer - I use a normal wheel and tyre (dura ace and conti), it's fine for 45 mins twice a week.
Posted : 06/12/2011 5:37 pm
As it happens I have a virtually new (used for about an hour and a half) tyre on e-bay... [url= http://www.ebay.co.uk/itm/170740231905?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 ]Here[/url] 😉
Posted : 06/12/2011 5:38 pm
I'd agree with the turbo-tyre, but why pi$$ around with the block/chain/rings? She's going to be using it in perfectly dry/clean conditions (I assume), so if you keep her well-lubed (ahem) the wear will be minimal. It will certainly be a lot less than if she was using the bike outdoors, and would you have changed those bits if that was what she was going to do?
Posted : 06/12/2011 5:39 pm
i thought conti did one, but can't find it now.
there's [url= http://www.wiggle.co.uk/schwalbe-insider-turbo-trainer-tyre-road-bike/ ]this from schwalbe[/url] after a quick google.
i'd stick the same block on a cheap wheel if the bike's staying put for that long.
Posted : 06/12/2011 5:40 pm
If it's going to be hooked up 'permanently', then just change the tyre for a turbo tyre on the standard wheel/chain/cassette and away you go. Loading on the wheel will be a lot less than out in the wild, as it were.
Using a spare rear wheel, with BBB cassette, cheap and cheerful from Ribble. Also use a specific tyre. Not used it much this winter, not cold enough to stop me getting out yet.
Posted : 06/12/2011 5:41 pm
+1 for the turbo tyre. I have a Conti one and it works fine, quiet, it doesn't overheat and it is fine, it is just a bit tough to get on for some reason.
Posted : 06/12/2011 5:43 pm
fair point RE: fully lubed and no grit etc.
OK, I'll go for a tyre - cheers for the link graham, but Im not going up against those windowlickers that bid on eBay 😉
Ill get a nice new one.
there's this one at wiggle
http://www.wiggle.co.uk/elite-coperton-indoor-turbo-trainer-tyre/
The schwalbe is out of stock at wiggle.
 Jase
I've used a turbo on normal tyres for years and never ruined one. As above, if using the bike soley on the turbo then a specific tyre wouldn't hurt but I would'nt bother with anything else.
Posted : 06/12/2011 5:45 pm
ribble seems to have some good deals.
Posted : 06/12/2011 5:46 pm
