Turbo trainers &...
[Closed] Turbo trainers & Garmin add ons
Just wondering, for training with the likes of the sufferfest videos, what would be more beneficial a speed/cadence sensor or a HRM as an add on?
Would the HRM enable me to better gauge the efforts displayed, say for example if it says 8/10 would you work at 80% of max?
As for getting max HR is it just a case of flogging yourself over a period of time and see what the peak is? In a mon scientific / laboratory test kind if way
Posted : 26/09/2012 11:00 am
I went for both (cheapest I found at the time was on Amazon) but if forced to choose I'd say HRM so you can gauge your effort by heart rate. More use for the lower intensity bits than the full effort times when you are just flat out. Cadence will give you a notional speed and distance as well as telling you your crank revs but they are maybe a little less usefull and you can count revs easier than heart rate I think.
Posted : 26/09/2012 11:07 am
 MSP
Cadence/speed & hrm & ant+ dongle & trainer road.
Posted : 26/09/2012 11:09 am
and I suggest you read up on HR zones etc. Your 8/10 being 80% of max is unlikely to be quite right unless the videos explicitly say that, if they ever suggest a level of 2/10 I'm not sure you will be able to get your HR to 20% of max.
Posted : 26/09/2012 11:10 am
I have 5 or 6 vids and I don't think at any point do they mention heart rate. Cadence speed is used however. As for the ratings I just go by perceived effort and rarely look at my heart rate as it lags behind too much.
Posted : 26/09/2012 11:25 am
 MSP
If your using sufferfest videos. then trainer road can estimate power with the garmin speed cadence sensor, and give targets that match the video.
Posted : 26/09/2012 11:37 am
MSP - what's trainer road?
Posted : 26/09/2012 11:45 am
 MSP
[url= http://www.trainerroad.com/ ]http://www.trainerroad.com/[/url]
Posted : 26/09/2012 1:28 pm
Gents ... how do you make sure your turbo and bike is set up the same on each session?
My turbo is basic and you have to screw the fly wheel into the tire, so to speak. Therefore I'm thinking trainer road is for me as the turbo "pressure" will never be constant.
Am I missing something obvious when setting up or do other turbo models make constant pressure possible.
Cheers all
Posted : 27/09/2012 10:28 am
same tyre pressure and count the turns of the flywheel screw. not exact but is a start.
Posted : 27/09/2012 10:31 am
 MSP
The pressure of the tyre on the flywheel doesn't effect the turning force required (unless the tyre is slipping on the wheel).
Posted : 27/09/2012 10:40 am
yeah, thanks ... there no getting away from it I'd thought of that but I do monumental amounts of faffing trying to get on my turbo as it is... guess l'll have to be more organised... but is trainer road worth it?
Posted : 27/09/2012 10:46 am
MSP ... re tire pressure.. Honest question are you sure, sir? Could you briefly explain please
Posted : 27/09/2012 10:49 am
 MSP
make sure your turbo is listed as one they can estimate power for, and give it a try, its $10 a month, so about 6 quid, and you can cancel at anytime, give it a try and see what you think of it.
I have a hdmi output on my laptop, so I put it on my bigscreen TV. I probably wouldn't use it without the sufferfest videos, IMO they fit together really well.
 MSP
Yes the resistance is provided by an internal mechanism (fluid/fan/magnet depending on model) the contact of the tyre on the flywheel has no effect on that. I guess if the tyre was under inflated then the ratio of cycle wheel turns to flywheel turns would change, which would effect it. But for normal use the differences would be too small to worry about. And it is only estimated power.
Posted : 27/09/2012 10:53 am
Good info ... thanks MSP
Posted : 27/09/2012 10:57 am
Hmmm. The force pressing the roller to the tyre will effect rolling resistance, and large changes will make a difference. I think some trainers use a spring to achieve a constant contact force.
Posted : 27/09/2012 11:51 am
 MSP
No it won't, there may be a small mechanical inefficiency between the tyre and the flywheel, resistance is provided by the trainer, you are not trying to move the tyre surface at a different speed to the flywheel surface, they should stay constant and just become part of the system that uses the force applied at the pedals to drive the actual internal mechanisms of resistance.
Posted : 27/09/2012 12:18 pm
if the tyre pressure is lower will it not change the gearing ratio between wheel and small roller (maybe negligable effect)
I'd always been told to keep the tyre pressure the smae, so i check it regularly.
Posted : 27/09/2012 12:20 pm
