anyway to tune the compression damping on an oem recon solo air with no external compression adjust?
Posted : 02/01/2010 10:01 am
anyone know?
Posted : 02/01/2010 12:32 pm
Oil weights will be the only way - but why you want to alter compression damping anyway??????
Posted : 02/01/2010 12:41 pm
Adding oil into the lowers wont harm them? Ive done the same to my Lyriks and Pikes (both had almost zero in).
http://www.cycletherapist.co.uk/step-by-step-guides/rock-shox-lyrik-lower-service/
Posted : 02/01/2010 12:44 pm
Because they tend to dive tj
Posted : 02/01/2010 12:58 pm
If they are diving too much its spring rates that are wrong. Increasing oil levels will increase ramp up but not alter initial spring rates. Increasing compression damping will slow dive but not eliminate it and will produce other undesirable effects
Posted : 02/01/2010 1:19 pm
Its an air fork TJ.
Posted : 02/01/2010 2:44 pm
