hi,
I have been offered a set of Tune Wheels and the front is a King QR hub, is it possible to convert this to a 15mm axle?
I had a look on the website but my comp' would not translate it from German and I have not found anything else.
Anyone have any experience or knowledge about this?
much appreciated
cheers
Rich
I don't think so. I'll have a closer look at mine for you when I go to the shed later.
Ok, a little further investigation because once I started thinking about it it could have been useful to change mine as well.... Anyhow, on an older King hub it's not possible. On the new ones it is. The way to determine which is which is to measure the ID of the bearing. If it's 15mm you are out of luck, if it's 17mm then you can use a 15mm TA.
cheers Sam, will have a look before i buy them. much appreciated
