Tubs- teach me
[Closed] Tubs- teach me
[#6286271]
A thinly veiled "what tyre" post. In this case the terrain is ironman wales (and a half in Devon in a few weeks). The array of tubs out there is baffling. Normally I would go for contis in clinchers, any reason to change old habits?
In terms of fixing them to a carbon rim, is tape or glue easier/more secure?
Posted : 21/06/2014 7:59 pm
Here's a great link: http://sprinterdellacasa.blogspot.co.uk/2009/04/how-to-glue-tubular.html
Don't be scared of glueing it's just common sense and not difficult or messy if you work steadily (with a cup of tea)
Posted : 21/06/2014 8:03 pm
You won't be faster on tubs but you might prefer the ride. In recent years I've given up saving them for race day, I train on them about 75% of the time, because they feel so much nicer. Whether that's worth buying into, I don't know. Maintenance wise, they're about the same - fewer punctures ime but more faff to fit new ones. . I use glue, I can change a flat in a couple of minutes at the roadside (if the goop doesn't work).
TT world championship won on clinchers last year iirc.
Posted : 21/06/2014 9:55 pm
I use tubs everyday , Contis Giro .
I use tape , front and rear in the summer but use glue for the rear in the winter . dont know why but when road gets wet , the rear tubs seems to be coming undone with tape . planet X are the cheapest for tape ( jantex ) .
I like the Giro , as you can undo the valve to put some latex in the tub . and then i use superglue to repair the outer casing . doesnt fix all the punctures but ok for most of them .
Posted : 21/06/2014 10:09 pm
Tufo tape.
Posted : 21/06/2014 10:15 pm
^ is worlds ahead of the old jantex stuff just cost a little more but not that much more
But with road tubless is there any need for tubs
At least for all us with out a pro level of fittness
Posted : 21/06/2014 10:27 pm
Not sure if there's a perceptible difference in ride quality between tubs and tubeless but I'm not about to buy new wheels to find out. So yes there is a need for tubs. Maybe when I'm the last rider in the chain gang on tubs I'll rethink, more of an incentive when you have to carry all your own spares!
Posted : 21/06/2014 10:33 pm
I very much prefer glue.
When you remove a tub, be it at home or on the roadside you may not even need to top it up if the spare is glued. I suppose the ideal is to have a used and glued (but not too much, old glue will do) tub as the spare. It goes on easily. I always had a few that would do this job.
Never managed to remove a taped tub with out half staying on the rim and half on the tub which means you start again.
I am not sure that road tubeless has quite caught up. You have a small choice of tyres and the variation in pressures that you can choose it not as great as far as I know.
It was only being the last of my mates with tubs that took me to clinchers about 3 years ago having bought my first sprint wheels in 1980.
I still worry about a blow out with clinchers at speed, Had 1, luckily a rear and admittedly on a 19mm 650c rear, and that was bad enough. Tubs don't come off the rim like that did.
I know little about which tubs cope with gunge to fix a hole. Tell me more.
Posted : 22/06/2014 3:34 pm
Never tried tape, glue has always been fine for me.
Gunge (I use pit stop) seems to work about 50% of the time. If on a training run I'd try it first before swapping the tub if it doesn't seal.
If it seals I'll use that tub til it's worn out because I've got stuck (literally) a couple of times when I've used a gunged tub as a spare. The inner tube sticks together inside, and you can't get sufficient pressure with a mini pump to break the bond. A good thrust of a track pump might do it (or co2 maybe) but it's time to phone for a lift home otherwise.
Posted : 22/06/2014 4:43 pm
Latex inner tubes and 25c clinchers will give 4/5 the ride for 1/5 the pfaff. And I have both, and have even commuted on Tufo tubs. An ironman is not the place to learn to change a flat tub.
Posted : 22/06/2014 4:53 pm
2 layers of glue max. Many websites say 3 layers applied over 3 days but this creates such a thick and lumpy layer which creates a big risk of the tyre slipping on the rim. Sadly I found this out to my own cost with the valve stem ripping off the tyre!
Tufo s33 have been great value for money too. Haven't tried others.
Posted : 22/06/2014 6:05 pm
I punctured three times in Ironman wales last year. Fortunately, I was on clinchers and could patch the inner tubes for punctures two and three. I finished whilst others on tubs didn't because they could only repair one puncture or perhaps two using foam and then a replacement tub. I now use folding Gatorskins for Ironman.
Posted : 22/06/2014 6:08 pm
