tubeless yellow rim...
[Closed] tubeless yellow rim tape
hmmm what am i missing here? presta valves drop into the tyre and you have to pinch the [i]inner tube[/i] whilst adding sealant? but thered be no inner tube! and cores flying across the room?? gulp.
im really liking the tubeless set up on my 29er like i said. so now im pretty sure id like to sort my older wheels out too. but ghetto seems to be the easiest, and probably best chance of getting a decent seal do you reckon? non tubeless tyres and fairly old mavic rims :-/ and also thinking the valve hole will be too big for a presta valve on its own. am i right?
im currently looking to spend a bit more at wiggle to use a voucher, but cant find any bmx size inner tubes on there.
and if its such a faff with the removable cores, am i right in thinking i can probably just buy a couple of bog standard bmx tubes and still use the 'unseat one side and pour in sealant' method?
cheers
Posted : 19/10/2009 10:52 am
Does anyone know if Bontrager valve cores work with the "tape method" or do they solely work with Bontragers own rim strips?
Posted : 19/10/2009 11:11 am
Hi D, you don't have to use Presta valves with removable cores as you can unscrew Schrader valve cores to add your sealant, you just need to get the tool (for a coupla quid I'd guess).
Posted : 19/10/2009 1:00 pm
yo steve
so schraeder valves on bmx inner tubes, a little valve tool and then im sorted?
Posted : 19/10/2009 1:31 pm
are 24" inner tubes any good for ghetto tubeless? i ask cos i need to spend a couple of quid more to use a wiggle voucher. and they dont sell 20" bmx inners, only 24".
any good to me? or do i really need a tighter 20" inner?
Posted : 20/10/2009 6:47 am
Page 2 / 2
