Tubeless tyres for ...
[Closed] Tubeless tyres for 'gravel bike'?
Currently running some old cheap wire beaded tyres, but looking for something a bit wider (37c) that I can run tubeless - I'm guessing folding bead tyres might save a chunk of weight(?). With what I gather is an increasing popularity of CX/gravel bikes, I wondered if there have been some new developments in tyres since I last looked ......over 30 years ago!
Ideally after something that'll cope with a few muddy rooty bits in the woods - current tyres are worn slick (I've had my wear out of 'em though:))
Any sensible suggestions welcome.
TIA
Posted : 06/07/2016 9:57 am
Isn't the standard answer WTB Nano TCS?
I have the non-tubeless wire bead version and they are ace, wish I had paid the extra for tubeless version now though.
Posted : 06/07/2016 10:37 am
Wtb nano race in tubeless version.
You can run the non tubeless ones as tubeless...
 tang
I run the nanno race non tubeless tubeless no probs. Look at maxxis rambler too. I've also tubelessed the mighty cheap vee tyre from crc.
Posted : 06/07/2016 10:45 am
Check your clearances!
I was running Nanos, but it seems my rear wheel has a slight buckle/flat spot which was causing a rub every revolution.
Currently on Kenda Small Block 8s (35C) there's loads of room for those with a crap wheel.
Posted : 06/07/2016 11:06 am
The schwalbe g-ones have proven to be really grippy and fast.
Posted : 06/07/2016 11:39 am
Happy with my On-One Gravel Roads.
Go up tubeless fine and hold air reasonably well though only available in 33c or 40c so might not quite fit the bill.
Posted : 06/07/2016 12:54 pm
Hutchinson.
Posted : 06/07/2016 2:44 pm
I'm yet to attempt to less on my TN719 rims. What kind of pressures am I limited to on a tyre sized around 37c?
Might give those WTBs a try
Posted : 06/07/2016 2:57 pm
*tubeless
Posted : 06/07/2016 3:59 pm
Thanks for the suggestions - pleasantly surprised that there are a few to choose from.
Posted : 06/07/2016 9:07 pm
What is your version of gravel? Mine is FC stuff and any tread is pointless. I'd be looking at something like Schwalbe S Ones.
Posted : 06/07/2016 9:46 pm
Yes it is. They are great all round tyres. I have the tubeless versions and offer plenty of grip off road, fine in the wet and when on the road with a few extra psi roll really well due to the center tread pattern.
You won't be disappointed.
Posted : 07/07/2016 12:52 pm
spec trigger.
Posted : 07/07/2016 12:55 pm
Specialized Trigger 2bliss here
Posted : 07/07/2016 3:37 pm
