Tubeless schrader v...
[Closed] Tubeless schrader valves
11 Users
Need a bit of help as my google-fu is lacking.
I have a set of these:
[url= http://www.chainreactioncycles.com/no-flats-tubeless-schrader-valve-kit/rp-prod94761 ]http://www.chainreactioncycles.com/no-flats-tubeless-schrader-valve-kit/rp-prod94761[/url]
and they are fantastic. Note the conical base, not the metal one with the O-ring.
I like these as they let more air in to seat and you can use a proper pressure gauge. Hotlines dont have stock and I cant find anything simular.
Any suggestions?
Posted : 11/07/2016 11:19 am
Stans do a tubeless Schraedar valve .
Posted : 11/07/2016 11:28 am
OP, there are some on ebay but I think they may be the metal base/o-ring type I'm afraid.
Posted : 11/07/2016 11:29 am
Ramsey - i presume you meant no flats / no tubes - stans. They have these hugo jobs on crc by they are only 35mm long. No good for the DT Swiss 471 rims I'm running.
Kayak, yep - spotted those, but metal base. I got a set already and they don't seal well round the rim. Nearly there, but not quite as they say!
Posted : 11/07/2016 11:43 am
They wouldn't fit in a 471 rim? It's drilled for presta
Posted : 11/07/2016 12:00 pm
wiggles - not that they wouldn't fit in the hole, they are only 35mm long. Not enough pokes through. You can only just get the nut on there, let alone a pump head.
Posted : 11/07/2016 12:27 pm
Why not just cut some from a few old inner tubes? I've done that a few times with Presta ones and it's worked fine
Posted : 11/07/2016 12:51 pm
dangeourbrain - not a bad idea that. How did you hold them in place, most dont have the thread all the way into the rim for a locking nut.
Posted : 11/07/2016 1:06 pm
I think all the schrader ones I've had have been threaded all the way down. Shouldn't be too hard to find some.
Posted : 11/07/2016 2:12 pm
Ideal, I'm figuring I could go one step further and run those as a form of strip too. Cut the tube open. Humm.
Posted : 11/07/2016 3:00 pm
Heard of that done many times using BMX tubes, presumably to make the fit is tight enough.
Posted : 11/07/2016 3:05 pm
I cut mine from old tubes & taped over them. Then bridged a hole through.
Been in there 18 months & working fine.
But ghetto tubeless from BMX tubes is the way to go. Virtually sealed as soon as the tyre is back on.
Posted : 11/07/2016 3:28 pm
Got a set of those exact valves from a project that didn't work. Can sell them for £5 posted if your interested
Posted : 11/07/2016 3:31 pm
These work well and work out really good value imho,rimstrips,tape and goo.
http://www.chainreactioncycles.com/no-flats-joe-s-eco-tubeless-system-all-mountain/rp-prod74009
Posted : 11/07/2016 3:39 pm
Pridds, thanks and YGM.
Posted : 11/07/2016 4:34 pm
