Tubeless repair is ...
[Closed] Tubeless repair is it worth it ...
.... A new winters coat and shoes for the wife...? Good song
Anyhow. Hole in sidewall of a rocket Ron just above the bead. It won't seal, and I have applied a park patch (those clear ones which I always thought were more 'get me home' before doing a proper repair) it still hasn't sealed properly although is a little better.
Is a stronger patch kit worth it? Which one? Or is it new tyre time (tyre is three rides old sob sob)
Thanks all!
Posted : 12/07/2014 9:10 pm
 jedi
weldtite worms will sort it
Posted : 12/07/2014 9:54 pm
I cut up an old tyre and superglue a patch of sidewall over the cut on the inside, it seems to work well, saves buying a new tyre!
Posted : 12/07/2014 9:56 pm
 cp
I repaired a small cut in my bontrager 29-1 that wouldn't deal with fluid...
Second ride out on it today, 45 minutes in, and I thought I'd been shot, the bang was pretty impressive!
Sidewall split right open.
Spare tube and a neoprene camera case stuck inside got me home...!
Posted : 12/07/2014 9:57 pm
Just above the bead is a tricky spot - you won't patch it. Need to plug it like the Jedi says. Even then it may not work, depends how close to the bead it is.
Posted : 12/07/2014 10:02 pm
Yeah I think that's the issue. There is maybe millimeters of patch covering the hole before the bead.
Thanks for the responses I'll google weldtite worms
Posted : 12/07/2014 10:06 pm
 akak
Hutchinson rep air kit. Although the glue in it does look like superglue.
Posted : 12/07/2014 10:20 pm
I repaired a tear like that with gorilla tape, just to get me out on a ride. I forgot about it till I knackered the tyre, months later!
Posted : 12/07/2014 10:23 pm
