tubeless puncture h...
[Closed] tubeless puncture hole won't seal
I've got 2 punctures whilst out today,& the stans fluid won't seal one of the holes any ideas ?
Posted : 21/04/2015 9:07 pm
Patch it or use an anchovy
Posted : 21/04/2015 9:14 pm
Too big a hole?
possibly old, dried out stans fluid? When did you last top up/change the fluid?
Posted : 21/04/2015 9:16 pm
Fluids 2/3 months old !
Posted : 21/04/2015 9:24 pm
Got a puncture on Sunday. Topped up with fresh stans fluid, pumped up, sealed lovely, back riding. I think if you top up every 3 months give or take a little, you should find those little holes will seal. Still impressed with tubeless set up.
Posted : 21/04/2015 9:25 pm
 pk13
Glitter?
Posted : 21/04/2015 9:27 pm
Whats an anchovies Simon ?,apart from stating the obvious !
Posted : 21/04/2015 9:28 pm
 pk13
It's a plug of rubber. I'm sure there are better explanations
Posted : 21/04/2015 9:30 pm
I'll top.it up tommora & stick some glitter in ,saves the kids thrown it all I've the house ,thx guys .
Anchovy or superglue
Posted : 21/04/2015 9:31 pm
[url= http://nextdaytyres.co.uk/details.aspx/weldtite-tubeless-tyre-outside-repair-kit-/250/811?gclid=cmfq1-yeimucfcjnwgod2jeaag ]anchovy[/url]
used for the first time at the weekend. surprisingly easy.
Posted : 21/04/2015 9:32 pm
 pk13
 br
and sometimes the tyre is only fit for 'tubed' use...
Try a standard tube patch on the inside of the tyre and superglue on the outside - but if out and about, I use an anchovy.
Posted : 21/04/2015 9:36 pm
I've learnt something there !
Posted : 21/04/2015 9:41 pm
You'll be best to use a gel type superglue if gluing a patch on. Something with a little stretch. I patch mine with a cutting from RIB repair material.
Posted : 21/04/2015 9:58 pm
Posted : 21/04/2015 9:59 pm
