Trying to decide be...
[Closed] Trying to decide between....
a Cross Check, and a Karate Monkey.
After being told by a surgeon that I may not be able to cycle again (but I can ๐Ÿ™‚ )I was a bit hasty in selling my Pomino and singlespeed. I' probably won't ride anything as GRRRRR as the black at Laggan again so the Trance is going too.
Each spring time I wish that I had a tourer, and think a Cross Check would fit the bill, but I also want something to be able to ride the grassy and not too severe singletrack and think the Karate Monkey would fit there (No I can't have both!).
Have a nice roadbike for the summer, my older steel roadbike is too similar - Cross Check again.
Not sure about canti brakes and the seatpost mounted canti hanger though -Karate Monkey can use discs.
Will the Karate Monkey be too heavy for winter road use though....
Argh! I'm waffling on now. Help me see sense.
Cheers.
Posted : 24/02/2010 11:22 am
Cantis are ok with the skinnier tyres used on cross bikes. Set up is a bit of a faff, but once you have worked the brakes idiosyncrasies, it's easy from then on. You could always use mini V-brakes. The cantis give you great mud clearance though.
I'd suggest going back to a Pompino, or the neat looking [b][u][url= http://www.genesisbikes.co.uk/bikes/cross/day-one/ ]Genesis Day One*[/url][/u][/b]
I regularly ride my Pompino on the sort of stuff you are talking about.
*I'd have one in a shot if I wasn't overloaded with bikes at present.
Posted : 24/02/2010 12:06 pm
