As the title says really.
Want to get the x0 carbon 1x10 DH cranks but just a little unsure if it will cause problems using with an xt rear mech?
Didn't know whether mixing manufacturers like that would be a problem?
Also, apart from the cranks and chainring and a new 73mm Gxp bb would I need to replace anything else?
Oh and it's all going to be fitted with an lg1+ chains device. Sound ok?
Posted : 09/04/2012 5:00 pm
It doesn't matter. The only real mismatch is with rear shifters and derailleurs as the manufacturers use different pull ratios. SRAM won't work with Shimano, and vice versa.
Posted : 09/04/2012 5:09 pm
Brilliant thank you ๐
Posted : 09/04/2012 6:58 pm
