Triple chainset roa...
[Closed] Triple chainset road front shifter question
5 Users
 RC
Can a triple front road SIS shifter be used with a double road chainset?
Thanks.
RC
Posted : 06/01/2011 3:29 pm
Usually, yes.
Posted : 06/01/2011 3:32 pm
I have used an Ultegra triple STI with a compact and it was ok. I would keep an eye out for an double s/h shifter if you are doing it long term, but if you are swaping back and fourth it would be ok.
Posted : 06/01/2011 3:37 pm
Depends which model but my 105's were fine and my old ultegras can IIRC if that helps? But the new ones are double/triple specific - what model - look them up on shimano tech docs if they are shimano of course 😉
Posted : 06/01/2011 3:38 pm
What Al says.
I have Ultegra 6600 STIs. L/H shifter is Triple specific (6600 was sold as triple specifc or double specific). I swapped a triple chainset for a standard double (with a compact double for those big days in the hills).
Shifter works fine, although I did need a double specific front mech. I set the shifter to use the granny for the inner ring, and middle position for the outer ring. Overshifting is blocked in the usual way via the f/mech limit screws.
Posted : 06/01/2011 3:52 pm
