Im trying to remove the rear shock from my 2019 Fuel ex - it seems determined it wont come out of the lower linkage. The bolts are out but can i buggery get it out of the lower linkage. Anyone had similar issues and figured it out?
Posted : 18/02/2023 6:45 pm
Undo the bolt on the main pivot, it will take tension out of the rocker. If uses same style as my Top Fuel of similar vintage
Posted : 18/02/2023 6:55 pm
Ah bugger, that means removing the crankset to get to the main pivot bolt...and somehow the cover that the self extracting bolt pushes against has gone missing....
Posted : 18/02/2023 8:51 pm
Shouldn't need to remove crankset to get at pivot, unless yours is a 2020 model with the shock direct to frame, loosening it is not going to make any difference I am afraid. May just be a really tight interference fit..
Posted : 18/02/2023 9:41 pm
