Travel change on re...
[Closed] Travel change on reba race 09 ?
Any one know if they will go to 140 -130 -120 from 100mm
thanks all
Posted : 03/01/2010 11:49 pm
You can remove a spacer inside and go up to 120mm (good PDF 'dealer service guide' on sram site for this) but you want revalations for 130-140mm travel.
Posted : 04/01/2010 12:13 am
thanks took some finding but got there .
Posted : 04/01/2010 12:31 am
what part of the service guide tells you this,call me thick but cant find it?
Posted : 04/01/2010 7:38 pm
yeah, its a monster of a document isn't it? You have to work out which 'chapters' are for your fork and then ignore the rest even if it looks very similar. I printed the relevant sections off for my fork(s) and left the rest in the computer so I could get all messy and not start doing the wrong bit to the wrong fork.
For the reba dual air:
1-Removing lower legs.
2-Dual Air spring service. In this bit it mentions the 'all travel spacers', which is the bit you need to do to alter the travel. It looks like a cylinder of plastic with a chunk cut out of it (so you can 'snap' it on, but do slide it off the shaft as it is all a bit delicate in there).
3-(optional) Motion control service.
4- Reinstalling the lower legs.
You can do it without removing the lower legs. There was a thread on here a couple of weeks ago which said how to but although its quicker and does not require the use of snap-ring pliers, you have to get a rather delicate seal past the big threads under the top cap. If it was mine (done it to a couple of forks) I would invest some more time and do it the way the service guide says, plus then you get to clean up the seals/foam rings, inspect the stanchions and bushings, and change the oil in the lowers.
Happy spannering!
Posted : 04/01/2010 7:59 pm
