Is there a simple product that would stop me accidentally 'pulling' the brake levers when the wheels are off and I'm placing the bike in the back of the car?
No matter how careful I am I always seem to end up catching one of them or putting the weight of the bars on it which then causes the disc pads to come together!
Easily pushed back with a small screwdriver, but I'm sure doing this repeatedly can't be good for the pads.
Bike racks aren't really an option because I need to be able to leave it securely in the car while I'm at work then heading out to ride afterwards.
Bleed blocks?
You can get a spacer that sits in between pads to stop this happening
Jam bo's picture is the proper thing but failing that a 2p coin and a bit of tape to hold it in place will work just as well.
I use some folded up paper wedged in between the pads, then elastic band around it so it doesn't fall out
I used to use those with my Shimano's, not been able to find anything for my new Hope's though (tbh I've not looked very hard).
It's only been an issue once when there was another bike laid on top of mine.
Ice lolly stick
FFS!
I knew that - why did my brain completely block out the memory that those things existed??
Thanks for reminding me that I'm an idiot
A thick piece of cardboard, lollipop stick or similar between the pads, elastic band around the lever and bar to hold it in place.
Job done.
Bits of cardboard, folded £20 notes, the list is endless
Take the pads out first surely, then push back will stop pad damage. Or are the pads wedged together by the pistons?
Hopes are far easier to push back with a screwdriver (without having to remove pads) without risking damage, so not as important IMO
JEngledow - Member
Hopes are far easier to push back with a screwdriver (without having o remove pads etc) without risking damage so not as important IMO
This is very true, it's still a ball ache when it happens though!
No, the pads just leave a gap that's about half of what it should be and not quite big enough to fit a disk in, so easy enough to get a small screwdriver in between and push them back.
I will be investing in a scrap of plastic or cardboard going forward now though
Fold your peice of cardboard or plastic in half and loop a small elastic band through the middle of the fold. When you insert folded item between the pads the elastic band can go over the caliper to stop it from falling out.
....alternatively if you want to go the deluxe route you could get one of these things which is designed protect the rear dropouts from being squashed together when without a wheel, holds the chain taught, and has a built in brake pad spacer:
