Transition Covert c...
[Closed] Transition Covert cable routing problem
My Covert has a strange cable route. it passes perilously close to the little ring as it heads towards the chain stay internal. I've already shredded the lot once and can see it happening again.
Any thoughts? different outers, chain guide?
[img] http://s8.postimage.org/sslz4t7nl/DSC_0003.jpg [/img][img] http://s8.postimage.org/ekwag5uyp/DSC_0002.jp g" target="_blank">http://s8.postimage.org/sslz4t7nl/DSC_0003.jpg [/img][img] http://s8.postimage.org/ekwag5uyp/DSC_0002.jp g"/> [/img]
Posted : 03/11/2012 3:23 am
Someone must have a bright idea?
Posted : 03/11/2012 9:44 pm
 jedi
Same on my bottlerocket and bandit. I just put a zip tie there to stop it bulging to the granny ring
Posted : 03/11/2012 9:57 pm
Abandon the granny ring and fit a chain guide?
Posted : 03/11/2012 10:07 pm
 jedi
I use 2x9 on both with no worries
Posted : 03/11/2012 10:15 pm
Get yourself the new Carbon Covert next year. It has internal cable routing. Problem solved.
Posted : 03/11/2012 10:39 pm
Isn't there a hole for a zip tie somewhere?
Posted : 03/11/2012 10:43 pm
There is a small hole to fit a cable tie through (as per SteveLol) see below. On your photo it seems to show two cable ties but located further back, perhaps they are in the wrong place. BTW thanks to Nirvana Cycles they built the bike and clearly know the tricks as I've not have any problems.
[img][url= http://farm8.staticflickr.com/7134/8151838464_81929a4a27_z.jp g" target="_blank">http://farm8.staticflickr.com/7134/8151838464_81929a4a27_z.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/78861811@N06/8151838464/ ]Covert Cable & Tie[/url] by [url= http://www.flickr.com/people/78861811@N06/ ]JambalayaPhoto[/url], on Flickr[/img]
I know how to party on a Saturday night, taking photos of cable ties !
Posted : 03/11/2012 11:00 pm
Thanks, zip ties x2 are through the wee hole but still managing to occasionally get the chain against the outer. Time for a chain guide...
Posted : 04/11/2012 8:19 am
Why not just use the back plate from a stinger/superstar copy and cut it down? There was one on here for £12 yesterday
Posted : 04/11/2012 9:12 am
Ive been giving my Covert a spruce up after a summers worth of [s]Dust[/s] mud and found this bit of cable wear that was hiding behind my chain guide! Another area that rubs nicely is the brake hose against the seatstay, i caught that one early on thankfully. The frame bearings were all dry and gritty and a couple had some corrosion, a bit poor on a 6 month old frame IMO.
Posted : 06/11/2012 9:09 pm
Just fitting a granny ring and found the same : (
Posted : 12/07/2013 12:14 pm
mine is kept out of the way by the chain guide backplate (MRP Lopes SL) and by a zip tie.
Posted : 12/07/2013 12:35 pm
Zip tie and chain guide seems to work fine for me. I've also zip tied the cable outer to the rear of the chain guide backplate to stop it rubbing behind like chopchop found out. So far so good.
Posted : 12/07/2013 12:40 pm
Zip tie thorugh the hole mentioned above works fine, my LBS left it off initially and I had the same problem
Posted : 12/07/2013 12:52 pm
move a NDS BB spacer to the drive side if there is one? Would give a couple of mm more clearance.
Posted : 12/07/2013 12:53 pm
Mine is zip-tied to the chain stay and i'm running a full guide! Glad i caught it now.
Posted : 12/07/2013 1:16 pm
