Righty,
My fault for relying on others to transport.
Mazda cx5 obtained a year ago with detachable towbar with single electrics as only used for Thule bike carrier.
Today was first time used. Unfortunately the electric on the car has ~13 holes all quite small but the one on the Thule has larger and less.
So...is it just a case if getting the Thule connector changed to match the one on the car?
Thanks!
Some thule racks have the 13 pin plug with a 7 pin adaptor attached. Yours might or you need to get hold of one.
13 pin is so you can run the fridge and lights etc for a caravan on one plug. You can get a splitter to make the 13 pin into two 7 pin plugs, you just won't use the grey one.
You can get an adaptor.
[url= http://www.amazon.co.uk/Waterproof-PlugTrailer-Caravan-Electric-Converter/dp/B005UUJ3DU ]amazon part[/url]
Or pop to Halfords...
Thanks all. Adapter ordered.
